My router stats - Can I squeeze anything more out of my line?
- My router stats - Can I squeeze anything more out ...
31-07-2009 7:50 AM
Link Information
Uptime: 1 day, 0:43:49
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,568
Data Transferred (Sent/Received) [GB/GB]: 3.07 / 6.66
Output Power (Up/Down) [dBm]: 12.0 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 13.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 4,590,356
CRC Errors (Up/Down): 0 / 1,080
HEC Errors (Up/Down): 0 / 944
At one stage I was getting 1728Kbps which meant I got a higher sync speed however that was a while back so only getting round to looking at things that I might be able to do to improve things, if anything.
I'm running Windows Vista x64.
Re: My router stats - Can I squeeze anything more out of my line?
31-07-2009 7:56 AM
Can you describe the phone wiring? e.g. is the router plugged into the master socket or extension, does every phone point have a filter.
You might achieve some improvement using an iPlate or filtered faceplate if you don't already have one.
31-07-2009 9:25 AM
31-07-2009 10:18 AM
Hope that helps,
31-07-2009 11:18 AM
31-07-2009 7:27 PM
31-07-2009 8:34 PM
Keep an eye on the Fibre to the cabinet project - therein lies your higher speeds
http://community.plus.net/blog/2009/06/12/plusnet-to-trial-fibre-to-the-cabinet-fttc/
31-07-2009 10:14 PM
01-08-2009 5:46 PM
Even if you can't adjust the SNR, using routerstats, understanding the SNR variation on your line and rebooting when it is at its best might squeeze out the bit of speed you want.
01-08-2009 6:08 PM
