turn on suggestions
My router TG585 V7
- My router TG585 V7
My router TG585 V7
My router TG585 V7
26-10-2014 6:42 PM
Grateful for some comments:
The 'internet' light (top button of five) is now flashing on/off non stop. Previously the light was on continuous when connection was made ever since I got it.
Connection to the net is OK.
problems coming up?
thanks
MIkeS
problems coming up?
thanks
MIkeS
Re: My router TG585 V7
26-10-2014 10:17 PM
On other Technicolor router, it's normal for the internet light flash, it just indicates activity on the connection.
I would expect this to be the same with the TG585 v7.
27-10-2014 9:14 AM
The manual for the router actually says that a blinking Internet light is attempting a connection (Where as on other routers, as npr says, blinking can mean data transfer). Your connection looks absolutely fine though from our side so I wouldn't think it's anything to worry about at this stage.
If you do find you start of have problems, let us know and we'll do what we can to sort you out.
Tony
Tony
