My ping is erratic.
- My ping is erratic.
My ping is erratic.
11-11-2009 8:33 PM
Some people that I have a ping of 40 with, will spike up to 800+ and keep changing way to much it's unbearable to play.
Re: My ping is erratic.
12-11-2009 8:45 AM
If (and only if) you have switched your modem/router off since you posted, you may find the situation different now (different gateway, some changes to the network etc). You may not want to switch the modem/router off and lose sync, in which case have a look for a Connect/Disconnect button on you modem/router interface. If you are new to ADSL broadband and not yet been connected for 10days, I would reboot your router before 3pm or after 9am (ie well into daylight) to get the best sync then leave it alone unless you have problems.
If you are having any speed or connection problems please post back some modem/router ADSL line stats. If you are still having problems with your ping, try doing a tracert to bbc.co.uk from the command prompt and post the results here.
14-11-2009 2:17 PM
But now today when I went to play it is like before again with me having insane pings with everyone ingame.
(the people with low pings aren't stable, it spikes like crazy.)
I done tracert to bbc.co.uk
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
D:\Documents and Settings\Ray~>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 22 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 58 ms 58 ms 60 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 61 ms 57 ms 62 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 70 ms 63 ms 61 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 64 ms 81 ms 58 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 78 ms 64 ms 63 ms 212.58.238.133
7 91 ms 56 ms 57 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 89 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 58 ms 58 ms 61 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 59 ms 58 ms 67 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 68 ms 68 ms 64 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 59 ms 82 ms 61 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 59 ms 60 ms 70 ms 212.58.238.133
7 58 ms 82 ms 65 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 87 ms 100 ms 99 ms dsldevice.lan [192.168.1.254]
2 66 ms 67 ms 78 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 59 ms 58 ms 84 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 64 ms 61 ms 69 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 58 ms 64 ms 62 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 71 ms 62 ms 88 ms 212.58.238.133
7 59 ms 65 ms 65 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
14-11-2009 4:56 PM
At least there is consistency there in the tracert's. The figures suggest that "Interleaving" is turned on on your connection. As a gamer you will want this off the reduce the lag.
Could you do a few ping bbc.co.uk from the command prompt and post them, just to confirm the situation.
As the Comms team don't work w/e they would not be able to address this until Monday. You could try phoning the CSC at Sheffield when they are very quiet and they may be able to deal with this straight away. It usually takes upto 24hrs for the order to be activated by BTw.
After posting your pings, and getting this issue addressed, you may find better help on such topics and the game on the Gamers Forum. Look out for ASBO DOG, he'll point you the right way (along with a few others).
14-11-2009 6:35 PM
1 75 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 75 ms 61 ms 60 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 66 ms 77 ms 60 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 69 ms 68 ms 76 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 61 ms 77 ms 65 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 59 ms 57 ms 62 ms 212.58.238.133
7 75 ms 59 ms 89 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 70 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 80 ms 62 ms 71 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 189 ms 66 ms 82 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 59 ms 80 ms 61 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 63 ms 58 ms 61 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 233 ms 59 ms 76 ms 212.58.238.133
7 71 ms 67 ms 68 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 19 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 61 ms 59 ms 58 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 64 ms 64 ms 58 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 58 ms 68 ms 56 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 70 ms 67 ms 60 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 61 ms 86 ms 59 ms 212.58.238.133
7 76 ms 64 ms 58 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 32 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 74 ms 61 ms 87 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 57 ms 61 ms 61 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 57 ms 72 ms 75 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 58 ms 68 ms 68 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 59 ms 59 ms 65 ms 212.58.238.133
7 62 ms 58 ms 59 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 68 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 65 ms 118 ms 60 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 61 ms 68 ms 81 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 296 ms 248 ms 210 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 74 ms 59 ms 79 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 65 ms 79 ms 59 ms 212.58.238.133
7 59 ms 58 ms 64 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
14-11-2009 6:42 PM
to start of with i would raise a ticket to get interleaving turned off and put on fastpath <a href="https://portal.plus.net/wizard/index.html?Ea82ChdSAqqwtYJcjZV%2Fjl8BeHfnW7ogQYILXVCBFsnFyRVJeEpVZrrGHDFWsmvQCsvo6bTYqNo%3D">interleaving ticket</a>
Also can you just check the status of your exchange <a href="http://www.nildram.net/support/tools/congestion_checker/">here</a>
The ping time you get to the PN gateway (2nd hop) depends on the idstance from london you are am just south of sheffield and get the following on fastpath
the first tracert is where i forgot i had utorrent running at 80% of my upload speed
Quote C:\Users\SparrowHawk>tracert bbc.co.uk
1 1 ms 1 ms 3 ms 10.0.0.1
2 18 ms 55 ms 81 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 179 ms 220 ms 223 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 19 ms 64 ms 17 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 17 ms 108 ms 29 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 88 ms 49 ms 34 ms 212.58.238.133
7 26 ms 50 ms 70 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 1 ms 2 ms 1 ms 10.0.0.1
2 19 ms 17 ms 26 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 17 ms 17 ms 17 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 17 ms 16 ms 16 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 16 ms 17 ms 17 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 17 ms 18 ms 19 ms 212.58.238.133
7 17 ms 19 ms 18 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
can you post your line stats please http://www.kitz.co.uk/adsl/frogstats.php if you can find them on the thomson what am most looking for is the error stats hec, fec, ES ect
14-11-2009 6:48 PM
can you run a wireshark why playing the game to capture its traffic and look at for the following on incoming packets 0xa0
how to http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
and to download http://www.wireshark.org/
15-11-2009 1:20 AM
Exchange status:
Quote Results for exchange: Washington
Congestion
Congestion status on this exchange is GREEN.
Your telephone line is on an un-congested exchange.
Major Service Outages
There are no Major Service Outages on your line at this present time
Line stats (I think this is what you were asking for)
Quote DSL Connection
Link Information
Uptime: 2 days, 13:59:57
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,096
Data Transferred (Sent/Received) [MB/GB]: 601.53 / 1.49
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 17.0 / 30.0
SN Margin (Up/Down) [dB]: 23.0 / 10.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 57,368
CRC Errors (Up/Down): 0 / 82
HEC Errors (Up/Down): 0 / 68
and my pings ingame are normal again (lowish and stable), seems it just comes and goes :X
15-11-2009 1:43 AM
15-11-2009 1:18 PM
15-11-2009 1:33 PM
Quote from: ASBO can you check with the wireshark app that this game is getting the right prioity on the PN network please
I ran the game with wireshark for 2 minutes, and again it is in crazy ping mode:
Some of the packets I are 0xa0, but some are also 0x40 and 0x20
Here I uploaded the wireshark results: (gotta scroll down a little to when gunz opens, port=7775)
http://www.zilefile.com/files/9399_d1jx7/gunz.pcap
15-11-2009 3:37 PM
i take it you running over ethernet to the router and not wireless, if wireless you could do with disabling thw WZC service to stop windows causing lag spikes when auto searching for routers.
an app that does this for you http://www.martin-majowski.de/wlanoptimizer/ you want to make sure disable background scan is ticked on this app
Re:My ping is erratic.
16-11-2009 3:29 PM
The order to remove interleaving is now placed and should complete for you tomorrow. Hope this has the effect you're wanting on the pings, please let us know
18-11-2009 12:26 AM
Earlier after college I came onto gunz and allmost everyone in a room of 16 people had 1000 - 2000 ping, and a couple had normal pings. (around 50)
So I reset my router and logged on again and it was fine this time, everyone ingame had normal pings 20-150.. I played for a few hours and then the pings went crazy again alternating from 50 ping to 400 to 1000 etc.
I'm not using wireless and I have been playing this game for 2 years with the same router/computer without this problem. :X
Also I think the removed interleaving has taken effect now because when my ping wasn't going crazy I had 20 ping with a few europeans.
18-11-2009 4:48 AM
your router may report the interleaving status as interleaved or fastpath
how does this game operate. ie are you host? as its strange that every ones pings are going through the roof at the same time. if its your line to fault you must be acting as the server (host) to effect every ones ping
could you post another tracert to bbc.co.uk now you belive your on fastpath and lets see what your ping to the gateway is like now
