My linespeed keeps decreasing
- Re: My linespeed keeps decreasing
30-06-2017 1:39 PM
When I first joined plusnet, around 10 years ago, I got 15-17mbps on my line. Over time this reduced to 12-14mbps and stayed that way for quite some time. Then a few years back it crept down again to 10-12mbps and then until recently a fairly constant 8-10mbps for the last couple of years.
In the last few weeks however I am struggling to get 4mbps. Is there a reason for the line degrading from 17mbps to 4mbps?
Other than the speed issue i am not aware of any particular dropouts etc.
Any chance someone could have a look at my profile and check if there's something going on behind the scenes? I would LOVE to get back to 17mbps but realistically even back to the 10-12mbps would be most welcome.
I really don't want to try switching ISPs and playing that lottery.
Regards
Stuart
30-06-2017 5:14 PM
Hi Stuart,
Welcome to the forums.
Going through your post, that's some drop in speed
The estimates for your line are still between 6.5 to 14Mb/s so I'd expect you to be getting more than you are.
ADSL Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Range(Mbps) |
Availability Date |
Left in Jumper |
WBC ADSL 2+ | Up to 8 | -- | 6.5 to 14 | Available | -- | -- | -- | -- |
Your line is syncing to the exchange much lower than I'd expect it to for the line stats:
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 8.4 | 25.4 |
SNR Margin: | 14.9 | 9.0 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 47050 | 1600786 |
Speed: | 828 | 5752 |
Maximum Stable Rate (KBPS): | 12480 | Fault Threshold Rate (KBPS): | 9984 |
Mean Time Between Retrains (Seconds): | 21275 | Mean Time Between Errors Upstream (Seconds): | 7092 |
Indicative Line Quality: | A | Mean Time Between Errors Downstream (Seconds): | 86400 |
First step is a line reset, so I've just put that through and you're now syncing at 6488, so whilst a slight improvement, still below what I'd expect.
I'd advise getting this reported to us as a fault at https://faults.plus.net
30-06-2017 5:14 PM - edited 30-06-2017 5:15 PM
Hi Stuart,
A warm welcome to the forums. There is much that you can do to help yourself here / obtain helpful guidance from other forum members.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.
Please use the following links to check the services available and their estimated speeds. From the first link, please record and report back the distance from the exchange. The second link advises of which fibre services (if any) are available on your line and their anticipated speed.
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
After that, also take a look at the speed issues self help guide - see the link below.
Chris posted just as I did!
10-07-2017 4:19 PM
Whilst my linespeed has now crept up to around 5.5mbps, this is still far below what i had previously. I cannot currently get fibre as Glasgow Central Exchange, Cabinet 7 is not currently enabled or forecast to be enabled.
Therefore getting the highest speed I can from the ADSL I am stuck with is very important to me.
I would happily pay more for more speed and throughput but no providers seem to offer this service.
10-07-2017 4:34 PM
12-07-2017 3:33 PM
The SNR seems very high at nearly 15, is there a reason this is so high?
I thought higher SNR resulted in lower speeds and that 6 was a more common target?
12-07-2017 3:45 PM
There is - the DLM is managing the line for stability in the presence of a suspected fault (based on the fact an engineer has been called for).
A higher SNRM does indeed lead to lower speeds and 6dB is the more common TARGET ... in the absence of faults / interference.
12-07-2017 4:10 PM
Would this still be the case even though I don't have a fault based on drop connections or not able to get connected.
As my issue is with low speed, it seems counter intuitive to increase SNR, reducing the speed, until a fault with low speed can be investigated.
I would like all restrictions or profiles to be removed or set to normal so I can monitor the situation and record speeds and SNR etc over a period of about a week before I agree to an Engineer's visit where I am liable if they cannot find a fault. Is this possible?
Regards
Stuart
12-07-2017 4:10 PM
Testing your line is showing your SNR margin at 6db and your line speed is below your estimates. The next step is to arrange an engineer visit, I've replied to your fault ticket too.
12-07-2017 4:12 PM
OK, Thanks.
It may be some time before I can arrange a day at home to have an engineers visit.
I will respond once I know.
Regards
Stuart
12-07-2017 4:21 PM
28-07-2017 8:11 PM
OK, so I had an engineer visit today, attached his gizmo to the socket and sync'd at 15mbps.
Attach my modem/router do a speed test on bt wholesale and get 5.5mbps.
I attached a brand new Billion router and it syncs with a downstream rate of almost 14mbps. With only my MacBook connected via ethernet and nothing elision on the router I still only get 5.5mbps???
I am beyond the limit of my knowledge here, how can the router sync at 14 and yet only throughput 5.5?
29-07-2017 9:02 AM
There are a number of possible reasons...
Either the BT or Plusnet IP profiles are wrong. In the BT speed test did you run the further diagnostics test? That will report your BT IP profile which should be 88% of the router synch speed.
Then there is the PN copy of that which will be rounded down to one decimal place. Sorry I can't give you a link to that as the phone based editor does not give me access to my stored macros. Sometimes a change to the profile is not properly handed off from BT to Plusnet / applied properly. There again I'm informed that if you are on the 'new' network, it has no bearing on matters.
The next potential reason is you've run the test over wifi and it's not as fast as it might be.
The other typical culprit is there is other hidden activity in your PC / network - system updates down loading / cloud backs being run st the same time as doing the speed test.
29-07-2017 2:29 PM
thanks for the feedback.
Wifi was disabled on both the router and my MacBook. so definitely not a wifi issue.
As far as I could check , no background activity running. tested multiple times over the day with same results.
To me this looks like a profile thing or plusnet setting but I'm assured that they have reset my profile.
29-07-2017 2:35 PM
By the way, the upload speed is around 85% of the sync speed and what I'd expect, however the download speed appears to be capped at 8mbps despite my sync speed being near 14mbps.
I stream from NFL Gamepass and Netflix and the throughput speed is hurting me. If anyone else in the house goes on line my stream turns to [-Censored-].
