My line keep dropping...
toastofleeds
I know I'm on a silly long line, but it's normally reasonably stable at just under 2Mb/s.
However, it's been dropping out quite a lot recently. Before I raise a fault, would there be any reason for this? Would Plusnet be able to see the reason for it dropping?
Also, there's been a new green cab put up pretty close to me (it first appeared at the beginning of the year) - what's the best way to find out the progress with it?
Fixes: 46
Re: My line keep dropping...
Checks and diagnostics aren't picking up on any obvious causes for the drops.
There's definitely an issue so I'd try following the checks here next https://goo.gl/tu2WWu
If those don't help it would then be a good idea to report a fault over at http://faults.plus.net
Let us know how you get on so we can follow things up with you.
 Adam Walker
Fixes: 31
If you put your telephone number into the DSL Checker you should be able to see if fibre is available, you may need to check every now and then.
