My internet radio can't find my network
- My internet radio can't find my network
07-08-2013 7:18 PM
Switched to PlusNet recently. PC and laptop connected wirelessly without any problems but my internet radio won't connect. I have entered the correct WPA code but it comes up with a timed out message.
If I disable the security it connects and works fine.
I should say it worked fine with my old router from previous provider. The manufacturer help page says that there could be a problem with the MAC address being blocked? Is that something I can check on the router myself?
It suggests setting it up with a static IP address - it tells you how to do it but not what to put into the IP address, DNS address etc.
Anybody come across the same problem and resolved it?
Keith
Keith
6 REPLIES 6
Re: My internet radio can't find my network
07-08-2013 7:23 PM
Upper case / lower case letters entered correctly ?
Message 2 of 7
(5,768 Views)
07-08-2013 8:34 PM
Yes, all entered correctly thanks.
Message 3 of 7
(5,768 Views)
07-08-2013 8:54 PM
What make of radio? My Roberts Stream 205 connected fine using WEP.
Message 4 of 7
(5,768 Views)
07-08-2013 9:01 PM
Tevion 5404
Although it asks for a WPA key my previous router did use a long WEP key. I tried switching the router to WEP and lost laptop connection and had to connect via Ethernet to change back and get onto internet again - didn't try anything else after that.
Message 5 of 7
(5,768 Views)
07-08-2013 9:19 PM
Prompted by your comment on using WEP I have changed the encryption to WEP and restarted the radio, entered info again, and it has connected! looks like it doesn't like WPA.
I have managed to get the wireless up and running on the laptop by changing the security type to 'shared' and putting the WEP key in.
Question now is am I OK running in this mode - the router wifi light is orange?
Message 6 of 7
(5,768 Views)
07-08-2013 9:40 PM
Finally sorted, with thanks to tijara33.
Feeling a bit braver now I had a connection I found the 'upgrade firmware' option. I took a deep breath when it said "ARE YOU SURE?".
t came back on after a while. I reset the security on the router to WPA and rejigged the info on the radio - it connected using WPA this time and I've got the green light back up.
Keith
Keith
Message 7 of 7
(5,768 Views)
