My friend,s internet not working
- My friend,s internet not working
27-07-2012 8:39 PM
Can anyone tell me what causes the internet not to work. Is it fixable?
She said the laptop said it cannot connect to the internet and I paid her a bit of money for the laptop and she want's me to take back the laptop her money but I am concerned that it will be something simple that is wrong.
Any advice
Re: My friend,s internet not working
27-07-2012 8:50 PM
First is the router connecting to the internet - all lights green
Second can the laptop see the router via wireless
If it can't take try connecting by wire (take one along to test)
Can the laptop see any other wireless stations if it can't see her router
27-07-2012 8:54 PM
What make of router
Is router connected via cable to laptop ?
Do you know the "security" code of the Router ?
If using wireless connection..... is the wireless actually switched on, on the laptop ?
Download "inSSIDer" onto a dongle, then onto the laptop, to see what wireless signals are available.... it should see the router if it is wireless as the most strongest signal.
the more info you can give ..... the more easy it will be to diagnose your problems....
27-07-2012 9:23 PM
Thanks for your help.
27-07-2012 10:48 PM
27-07-2012 11:02 PM
28-07-2012 12:15 AM
You say that all lights are green I have a sneaky feeling that it is a Super Hub
If it is a Super Hub it should have a Blue Light flashing on it that is the top Light should flash Blue!
If the Light is not Blue and flashing the wireless connection is not connected.
The "Default Security Code" of the Super Hub is on the Back of the Super Hub.
Call NTL on any NTL Phone on 150 and go to Broadband for help setting up the Super Hub.
Hope this helps!
[Edit] Added Linke
How do I set up the Virgin Media Super Hub?
28-07-2012 7:24 AM
28-07-2012 10:19 PM
29-07-2012 7:45 AM
