My fibre speed has dropped off a cliff, unacceptable.
- My fibre speed has dropped off a cliff, unacceptab...
28-06-2014 9:24 PM
At first I thought maybe someone else in the house is hogging the bandwidth. I then decided to dig a little deeper.
so did the BT checker:
What is going on?
Why am I paying for FIBRE and getting less than ADSL? Will I be reimbursed pro rata for denial of acceptable service?
Re: My fibre speed has dropped off a cliff, unacceptable.
28-06-2014 9:39 PM
28-06-2014 9:45 PM
Intermittent fault, caused the DLM to go ape-sheet due to excess errors or noise on the line
Banded the line to a low speed on the download ......and there it will sit until the fault is found/cleared and DLM reset.
Reasonable guess for a Saturday evening?
28-06-2014 9:53 PM
28-06-2014 10:06 PM
I've updated it manually to match the IP profile now.
28-06-2014 10:17 PM
28-06-2014 10:31 PM
Quote from: Scott Yup, looks to be a spurious update, we received an update for 13.1 on our side.
Hi Scott,
Good to see you back on the forums, especially on a Saturday night.
Spurious update from BTOR's systems? This profile update more applicable to (the previous?) ADSL service coming through for a fibre service seems to be a reoccurring theme. Has anyone looked at why?
Kevin
28-06-2014 11:19 PM
Quote from: Oldjim Note that it may be necessary to disconnect/connect the router using the web interface to activate the new profile
hi jim, any link to a tutorial on how i can carry this out?
29-06-2014 9:07 AM
30-06-2014 9:54 AM
The sync rate has now returned to normal, but due to the excessive amount of errors that have been evident on the line over the past few days, I would certainly raise a fault at http://faults.plus.net so that we can get this looked into.
30-06-2014 9:58 AM
30-06-2014 10:00 AM
Your line has the potential to do the same again, I'd advise raising a fault report. It's completely up to you though.
18-07-2014 6:50 PM
dick:quote
19-07-2014 3:14 PM
Are you able to run another speed test like you did previously. Everything appears fine from this side, the speed profile is set correctly.
19-07-2014 10:44 PM
