My disconnects
- Re: My disconnects
My disconnects
14-03-2011 9:04 PM
Recently the margin appeared to be reducing, until the drops of last night and this morning (see pdfs), and also DSL info from router
Other matter related? http://community.plus.net/forum/index.php/topic,94312.0.html
DSL Connection
Link Information
Uptime: 0 days, 8:00:29
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,048
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 25.0 / 46.0
SN Margin (Up/Down) [dB]: 17.5 / 5.0
Loss of Framing (Local/Remote): 22 / 0
Loss of Signal (Local/Remote): 93 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 324 / 0
FEC Errors (Up/Down): NA / 0
CRC Errors (Up/Down): NA / 992
HEC Errors (Up/Down): 0 / 807
Connection is by Ethernet via a hard wired in cavity extension off main socket immediately below.
jim:green quote shrunk to remove blank lines mod:end
Re: My disconnects
15-03-2011 8:11 PM
Re: My disconnects
16-03-2011 11:28 AM
Re: My disconnects
18-03-2011 7:37 AM
It is most unusual for a thread started four days ago not to have any third party responses; not like the Plusnet Community at all :o.
So, please, what's the problem?
Re: My disconnects
18-03-2011 11:26 AM
http://community.plus.net/forum/index.php/topic,94353.0.html (Last 24 hours) and guided by advice from another forum, I have raised a ticket 40892221 asking that my Interleaving status be checked to see if it is actually ON These from my router, I am told indicate it is OFF
Link Information
Uptime: 1 day, 17:22:27
Bandwidth (Up/Down) [kbps/kbps]: 443 / 5,379
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 2.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 25.5 / 46.0
SN Margin (Up/Down) [dB]: 16.5 / 8.5
Loss of Signal (Local/Remote): 144 / 0
Error Seconds (Local/Remote): 491 / 0
CRC Errors (Up/Down): NA / 3,243
HEC Errors (Up/Down): 0 / 2,581
Re: My disconnects
18-03-2011 1:56 PM
Have you worked through the dropping connection guide and if appropriate reported a dropping connection fault at http://faults.plus.net/? If the faults analysis process requires interleaving to be on it will happen.
In fact the setting might be "auto" but the DLM has turned it off because it doesn't feel it's needed.
Re: My disconnects
18-03-2011 2:09 PM
A 2wire 2700 router can, & Netgear DG834 GT has a good crack at it.
There are well know issues with IFTN huawei msan's on long lines .
If you need fastpath for gaming ect, then a router change might be the way to go. If not (INP 2) "should "settle things down.
Thx F9o
Re: My disconnects
18-03-2011 2:43 PM
Quote from: spraxyt Just wondering how interleaving status is related to the subject of this thread?
No but does to the thread that seemed to have been disregarded.
As yet not, but all the connections look firm. I have two spare tailed filters of varied shape of unknown provenance, so maybe I should get ones that are new?. Lastly I need to find a convenient time as running a wire from test socket on gf to 1f bedroom is a a pain and not on Er Indoors' approved list.
Quote Have you worked through the dropping connection guide and if appropriate reported a dropping connection fault at http://faults.plus.net/? If the faults analysis process requires interleaving to be on it will happen.
Quote In fact the setting might be "auto" but the DLM has turned it off because it doesn't feel it's needed.
Unaware that auto existed for interleaving, so DLM sees a good connection and sets fast path, and EU suffers drops with result that connection is worse than it would be! OMG!
Re: My disconnects
18-03-2011 3:00 PM
I believe you, but OOI is there any "official" evidence, or id it empirical?
Quote from: Force9Original The speed touch can't really handle a IFTN msan on fastpath with loop loss over 40db. ( it can struggle on interleave as well )
Both are legacy IIRC. I am wary of Ebay. What chipset do they have. Isn't Broadcom reckoned to be best?
Quote A 2wire 2700 router can, & Netgear DG834 GT has a good crack at it.
Quote If you need fastpath for gaming ect, then a router change might be the way to go. If not (INP 2) "should "settle things down.
No gaming, but what is INP2?
Re: My disconnects
18-03-2011 3:36 PM
Re: My disconnects
18-03-2011 3:41 PM
Re: My disconnects
18-03-2011 4:05 PM
Have a search on there or ask, about the dreeded IFTN msan's on long lines. (If you know a friendly BT Openreach Frames Engineer ask what they think of them)
The 2 wire works well by pairing the two infineon chipsets & the filmware generally better. ( Version 6 is a little buggy on the BT version)
http://www.kitz.co.uk/routers/2wire_2700_HGV.htm
BT sent loads of 2wires out to their business clients. Hence you can pick up a brand new sealed version for less than plusnet charge for their speedtouch. Just research the filmware versions first. They work out of the box on Plusnet no matter which BT filmware is pre- installed ( no unlocking). Lots of info on the link below
http://bt2700hgv.tripod.com/002.htm
As for broadcom's they like the most routers, work best if paired to a matching msan.
When used on a huawei , the broadcom based chipsets 6338 through 6358 can be hit & miss.
Taking the speedtouch family of routers for example, the 6338 which is in the 585v7 doesn't perform as well as the 6348 thats in the earlier 585v6. The newer 6358 found in the later speedtouch 587n's also peform better than the 6338's. Filmware also has a lot to do with how well the broadcoms perform. Generally the Broadcom netgear routers seem to read line data better than the Thomsons.
INP = Impluse noise protection & its relevant levels of setting.
thx f9o
Re: My disconnects
18-03-2011 5:34 PM
Re: My disconnects
18-03-2011 5:46 PM
BTW had a drop just before 17:00 with server and sync change, this time upwards,
Time Message
Warning Mar 18 16:58:27 PPP link up (Internet) [87.114.237.220]
Info Mar 18 16:58:27 PPP CHAP Chap receive success : authentication ok
Info Mar 18 16:58:26 PPP CHAP Receive challenge (rhost = pcl-ag01)
Info Mar 18 16:58:26 PPP CHAP Receive challenge (rhost = bras-red5.bs)
Warning Mar 18 16:58:10 PPP link down (Internet) [91.125.83.223]
Info Mar 18 16:58:00 xDSL linestate up (ITU-T G.992.5; downstream: 5827 kbit/s, upstream: 443 kbit/s; output Power Down: 20.0 dBm, Up: 13.0 dBm; line Attenuation Down: 46.0 dB, Up: 25.5 dB; snr Margin Down: 9.0 dB, Up: 21.0 dB)
Info Mar 18 16:57:35 xDSL linestate down
Info Mar 18 16:57:10 xDSL linestate down
Re: My disconnects
18-03-2011 6:13 PM
Certainly with the full version on my DG834G v4 I get this chart and it is very useful
