My desktop computer location is not reported correctly by Windows or the Internet.
- My desktop computer location is not reported corre...
22-02-2018 6:29 PM
I'm using a desktop computer with Windows 10, so there's no fancy GPS like laptops, smart phones or tablets might have.
Any web services that respond to my location report consistently that I'm a hundred or more miles from where I actually live.
Why is this, and how can I correct it?
As an example: https://ctrlq.org/maps/where/ or https://www.where-am-i.net/ report that I'm in Newbury
If I run a VPN, the location tools report an appropriate location.
I'm actually in Dorset and http://usertools.plus.net/@gateway tell me my Point of Presence is in Colindale.
thanks in advance
Simonides
Re: My desktop computer location is not reported correctly by Windows or the Internet.
22-02-2018 6:45 PM
Nothing you can do about it.
22-02-2018 7:17 PM
For location aware apps & websites setting a default location in Windows 10 may help.
23-02-2018 8:00 AM - edited 23-02-2018 8:03 AM
Thanks Browni - that seems not to help. I've set my location but https://www.where-am-i.net/ still thinks I'm in Newbury!
Thanks dvorak - I think you may be right, nothing I can do about it, unless anyone else has an idea!
Simonides.
23-02-2018 10:09 AM
A warm welcome to the forums.
The geolocation information is not so much about where your PC is, but rather where the currently allocated dynamic IP address is thought to be.
Geolocation data gathers use various methods to work out where an IP address is - for example one technique is to associate GPS data from (say) a mobile phone connected (via wifi) with the IP address THEN allocated to the router. Such data association can out last the duration that a particular router has that dynamic address.
Some would argue caution about allowing external systems to know exactly where you are.
23-02-2018 10:26 AM
Is there a particular reason you wanted the location of the desktop to be shown? I'm asking in case we can recommend a different solution for you.
Alternately if you were just wondering why it's showing as Colindale then it's not something that could be changed.
on 23-02-2018 12:30 PM - last edited on 24-02-2018 3:41 AM by Mav
Hello Adamwalker - only that some website provide content tailored to one's location. An example is https://places-to-eat-near-me.com/restaurants/ which provides me with an excellent selection of restaurants in Banbury - an impressive 123 miles to my North!!! This set me thinking : first why is this happening and second what could I do, if anything, to correct my location.
thanks
Simonides
Moderator's note by Mike (Mav): Post released from Spam Filter.
24-02-2018 6:34 AM - edited 24-02-2018 6:42 AM
I would check your browser settings for allowing location as that site does request location from my browser
which it gets correct after I click allow.
That could only have came from the default location I set as geoip location services show either Sheffield or Colindale for my location.
