My connection is on the deck... Profile?
- My connection is on the deck... Profile?
23-09-2010 9:08 PM
How do I get to see my profile?
cheers
Chris
Re: My connection is on the deck... Profile?
23-09-2010 9:17 PM
https://portal.plus.net/view_my_broadband_usage/index.php?&strAction=PERIOD
23-09-2010 9:19 PM
23-09-2010 9:22 PM
23-09-2010 9:36 PM
With that variation are you using Kaspersky
To get your IP profile you would need to run the BT speedtest but at present it is unreliable so the best bet at present is to get your Current Line Speed from here as it is supposed to mirror it https://portal.plus.net/my.html?action=data_transfer_speed
23-09-2010 9:42 PM
The speedtest thing is wierd - It hovers around 2450 area for about half of it & then flys off the scale. - Upload is constant.
I have been using Kaspersky for years - Its only Anti-virus not all that other jazz they do..
Thanks for looking at my post.
23-09-2010 9:46 PM
01754******
Phone exchange:
SKEGNESS
Estimated line speed:
8 - Checked on 2010-01-31 10:56:59
Current line speed:
7150
23-09-2010 9:51 PM
The other thing is to try the TBB speed test http://www.thinkbroadband.com/speedtest.html which does work even with Kaspersky active - this is mine with KIS running and a 3000kbps IP profile
Date 23/09/10 21:49:56
Speed Down 2651.94 Kbps ( 2.6 Mbps )
Speed Up 376.92 Kbps ( 0.4 Mbps )
You do need to run the test when wired as the problem may be the wireless connection
23-09-2010 9:55 PM
Thanks for the info on the speedtest though - It was consistant with Kaspersky paused.
23-09-2010 10:04 PM
23-09-2010 10:05 PM
23-09-2010 10:39 PM
I've just ran a line chack and your BT profile is definitely 7150. I've had a scout around and as yet can see no issues with your exchange or the network (although these things are only normally obvious when there have been many similar reports)
Jojo
24-09-2010 10:52 PM
