My broadband's out (again)
grumpybob
Anyone else in the south of England experiencing a complete broadband outage? Anyone got any idea what is wrong and when it will be fixed? There's no info on Plusnet's "Service Status" page (surprise, surprise).
Note to Plusnet: Erm ... guys, I've got work to do this evening ...
RTNI
Re: My broadband's out (again)
Given there are over 150 calls waiting at present it sure looks like there is an incident.
StevieR
I'm in the NorthWest and router stuck on authentication failed so something is a bit broke somewhere ;(
Teloriun
Same as stevier, lcath exchange... Authentication failure..maybe worth updating the service info page as it sounds like its a bit fubar Sad .
briggy2501
Nottinghamshire Area here.
Having the same problem. Was working before I left for work at 8am this morning. Ran as many tests as I could and started looking for any info.
Anyone getting this same problem on the test?
Test Results
Test Succeeded DSL
Test Failed ATM
No ATM activity detected on your DSL line.
Test Failed PPP
Your connection is currently down.
Guess I'm just going to have to wait?
grumpybob
Not just me then.
Still nothing on the Plusnet "Service Status" page. You've got to ask yourself, what's the point in having a Service Status page if you're not going to keep it current.
What a pain in the ....!
Plusnet Staff
Plusnet Staff
Fixes: 5
We're working on it: http://usertools.plus.net/status/archive/1405018557.htm
Sorry for the delay.
Chris Pettitt
Cloud Environments Engineer
drj
Gloucester - went out about 6.30pm - came back 8.12pm
drj
Went off again 8.29pm - back again 8.30pm - down again 8.40pm - back again 8.41pm  EDIT - Remains unstable - down and up again at 8.47pm, down at 8.49pm up at 8.50pm
Data rate up has plummeted from around 888 to 469 - conversely data rate down is better than usual (2800ish) at 3079 - EDIT now Data Rate Up : 667  Data Rate Down : 2915
Plusnet Staff
Plusnet Staff
Fixes: 5
The issue should have now cleared.
Chris Pettitt
TORPC
Mine also went out
Called support
Told BT outage country wide, affecting over 5000 customers
mine has been restored as of 10 - 15 mins ago
Edit:
I forgot to add
I had to reinsert my username & password to connect as it defaulted to the tr069 details
ATM the connection is slow, worse than dial up
will reboot router, them post screenshots
Scrambler2
Quote from: Chris
It hasn't. Still up and down like the proverbial.
TORPC
Mine has also been up & down
Throwing up DNS connectivity error messages
I have tried your dns / googles dns & openDNS
Factory reset & still the same
Here are the screenshots to compliment my earlier post
The message I received after I inserted my username / password
After refreshing the page
I have a fairly decent connection atm / will continue to monitor
Can I please have a copy of the radius log to compare with my reboots / factory resets etc
Fixes: 10
It was BT!
http://status.aa.net.uk/apost.cgi?incident=1965
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
drj
Stable in Gloucester since 8.57pm
