My broadband is slow
- My broadband is slow
07-02-2011 3:01 PM
How fast my line can go
I first checked how fast my line can go at http://www.btwholesale.com/includes/adsl/main.html, the result is below.
Maximised image here: http://i55.tinypic.com/25ku646.jpg
First speed test done today at about 14:20
I did a speed test at http://www.speedtester.bt.com, the result is below.
Maximised image here: http://i51.tinypic.com/28b6x47.jpg
The problem is the slow speeds i get during the evenings which is about 0.5mb. While on the value pack i noticed download speeds of up to 5.5mb that now (while on plusnet extra) has been reduced to 2.5mb with the evening remaining at 0.5mb. As i can see from the screenshot i took at btwholesale, my line should support speeds of up to 5mb yet speedtester.bt said otherwise.
Message 1 of 2
(650 Views)
1 REPLY 1
Re: My broadband is slow
07-02-2011 9:12 PM
Hi paqize,
I'm sure you will get much better speeds than what you currently achieve. I will deal with this for you on your other thread here.
Jojo
Jojo
Message 2 of 2
(319 Views)
