My Upload should be uncapped by now, but isn't...?
VictoriaIceni
After having problems with drop outs, there was a fault discovered and then corrected on my line. And although the download profile speed is nearly what it was before (20,000 instead of 22,000) the upload speed has remained a very slow 446, when I used to have 1,200. I've noticed the difference when uploading photos to the internet for the family.
I was phoned last week by a Plusnet operator(Blake) dealing with my case and he was going to uncap my upload speed to raise the speed, and it should have been done by last Thursday. I allowed for the holiday weekend, but it still hasn't changed. I've not restarted my router to see if that would help, because I didn't want to disrupt a connection that might still be tested.
I haven't had any more drop outs(crossing fingers!), but I would like to get my profile nearer to what it was please.
I was also told initially that 'interleaving' was turned on and then left off, but my ping remains at around 30-40 rather than 15, so I'd like to know if that's still turned on. The ping hasn't affected anything I do as I don't game much online, but I thought I'd mention what I've seen in speed tests.
My current DSL readings from my router(TG582n)...the last time it went down was when it was supposedly reset for the uncapping last week.:
Uptime: 7 days, 6:22:14
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 446 / 20,822
Data Transferred (Sent/Received) [GB/GB]: 0.98 / 12.73
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 9.4 / 15.5
SN Margin (Up/Down) [dB]: 31.6 / 6.3
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 70 / 0
FEC Errors (Up/Down): 9 / 15,995
CRC Errors (Up/Down): 0 / 95
HEC Errors (Up/Down): 0 / 7,999
2 REPLIES 2
HarryB
Fixes: 256
Re: My Upload should be uncapped by now, but isn't...?
Sorry to see your upload is still capped. I've passed feedback on and I'm placing an order now to uncap the upload. This should complete some time tomorrow.
 Harry Beesley
VictoriaIceni
Thanks for getting back to me so quickly. Thumbs_Up
Fingers crossed, for the next couple of days.
