My TG582n just got itself in a tizzy after about 46 days running
- Re: My TG582n just got itself in a tizzy after abo...
12-05-2014 9:17 PM
There is nothing showing in the logs or on the BQM and browsing and speed tests are fine
I won't be doing a reboot tonight as it would cripple my speed
Re: Something odd happened with my TG582n
12-05-2014 9:19 PM
12-05-2014 9:25 PM
Browsing and speed tests were fine
Accessing the router via the usual system was horribly slow both the initial connection and subsequently changing pages. There was nothing showing on the router log
Then it rebooted itself
Any thoughts on what could have happened
I only lost about 150kbps which could have been a lot worse
Re: My TG582n just got itself in a tizzy after about 46 days running
12-05-2014 9:26 PM
12-05-2014 9:32 PM
12-05-2014 9:35 PM
12-05-2014 9:36 PM
However I know that using telnet you can see a lot more
However as it just did a warm kernal reboot I can't check it
No it isn't overheating - it is just slightly warm to the touch
12-05-2014 10:01 PM
AFAIK the clear log file in the GUI does clear everything whereas a reboot does not always clear all the log.
I've never experienced this myself but I have seen reports / claims that a large log file slows the routers response times. It would have been interesting to see if clearing the log fixed your issue.
12-05-2014 10:12 PM
My log seems to pop back after clearing mine from the GUI ?
12-05-2014 10:23 PM
The GUI command clears the file in my TG672, surprised it's not the same with the TG582n.
13-05-2014 10:10 AM
What you are seeing in RouterStats is a known issue. According to the author, you should never see tone data on the summary tab; doing so indicates that RS has lost internal messages. This can be fixed by stopping & starting the RS capture.
What do the router error counts look like? I have seen high FEC rates make a router very unresponsive.
Kevin
13-05-2014 10:14 AM
Error rates weren't a problem otherwise it would have shown up in the speed tests or the BQM
13-05-2014 10:23 AM
I've seen RS cough every few minutes then suddenly work with out issue for days. I have no firm evidence, but I suspect that it is down to responsiveness of the router's admin interfaces both http & telnet.
Kevin
13-05-2014 10:28 AM
13-05-2014 10:31 AM
Must get round to updating the firmware
