My Speed.
- Re: My Speed.
My Speed.
08-09-2012 11:00 AM
Re: My Speed.
08-09-2012 12:24 PM
Re: My Speed.
08-09-2012 12:33 PM
Link Information
Uptime: 21 days, 16:05:49
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,208
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 15.0 / 16.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 16 / 0
Loss of Signal (Local/Remote): 65 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 241 / 0
FEC Errors (Up/Down): 145 / 1,886,116
CRC Errors (Up/Down): 145 / 2,307
HEC Errors (Up/Down): 72 / 2,033
m,here i think is my stats.
Re: My Speed.
08-09-2012 12:45 PM
The BT speedtest asked for in the link will show which it is.
However if you are getting speed test results of about 1650kbps then it is likely you are on 21CN and the Plusnet profile will be 1900kbps
Your speeds won't improve while you have a default noise margin of 15dB.
The speeds you are getting are actually very good for the reported attenuation and noise margin so a reduction in noise margin to 9dB will give a significant improvement
You can either wait to see if that changes automatically - this could take several weeks if it happens at all - or ask for a retrain
Have you tried using the test socket to see if the sync speed improves - the link I gave in my first reply gives the information
Re: My Speed.
08-09-2012 1:37 PM
Re: My Speed.
08-09-2012 1:49 PM
Re: My Speed.
08-09-2012 4:54 PM
Re: My Speed.
08-09-2012 4:55 PM
Re: My Speed.
08-09-2012 5:15 PM
Given the difficulty of getting it done through the ticket system I would suggest waiting for it to be picked up here on Monday
Re: My Speed.
08-09-2012 5:42 PM
Re: My Speed.
08-09-2012 5:49 PM
Quote from: owlguard Hiya Reeds Richards,ive tried that to no avail.
Just now, I presume, because you clearly had not tried it for 21 days, 15 hours, 5 minutes and 49 seconds. I'm still mystified as to what Zak thought he had done that would take 72 hours to take effect.
Re: My Speed.
09-09-2012 8:19 AM
Re: My Speed.
09-09-2012 8:28 AM
Re: My Speed.
09-09-2012 9:21 AM
Re: My Speed.
10-09-2012 2:04 PM
It seems from your re-sync that you had a few days couple of days ago that your profile has changed. I have manually changed this for you, your profile is now set at 3MB/s.
Let me know how you are getting on.
Chris
