My Opinion
- My Opinion
My Opinion
30-04-2009 7:24 PM
I have been with PlusNet for a year now, and I have been very happy using PlusNet as my ISP, so thank you to all the employees for
making possible that I can have a enjoyable time here.
What I like most about PlusNet, is that I can host my own web site, which comes in very handy.
The thing I like hate most, is that I live far from the exchange and my connection is rubbish:
Date Download Speed Upload Speed
Today 18:43 472 kbps (59kB/s) 278 kbps (34.8kB/s)
Today 15:05 472 kbps (59kB/s) 267 kbps (33.4kB/s)
Today 01:11 463 kbps (57.9kB/s) 267 kbps (33.4kB/s)
Yesterday 18:13 470 kbps (58.8kB/s) 261 kbps (32.6kB/s)
Tuesday 13:11 435 kbps (54.4kB/s) 373 kbps (46.6kB/s)
Monday 17:05 458 kbps (57.3kB/s) 319 kbps (39.9kB/s)
This has nothing to do with PlusNet I guess, but it is annoying.
Well that’s all for now, maybe if am here in a years time I will post another topic to let you know how things are going.
All the best PlusNet
Frangal
Ps. What is LLU trials?
Re: My Opinion
30-04-2009 7:29 PM
There aren't any - perhaps you mixing up the fact that LLU via Tiscali is being discontinued.
Re your speeds - I appreciate you are a long way from the exchange but perhaps the experts here can improve things a bit.
Can you post your router stats - attenuation, speed, noise margin
Re: My Opinion
30-04-2009 7:32 PM
Re: My Opinion
30-04-2009 7:33 PM
Re: My Opinion
30-04-2009 7:43 PM
Overview of Device Information
System Up Time 00:00:02:51
ADSL Speed (DS/US) 960/448 Kbps
LAN IP Address 192.168.1.1
Default Gateway 195.166.128.64
Primary DNS Server 212.159.6.10
Secondary DNS Server 212.159.6.9
Firmware Version 3.30r
Boot Loader Version 1.0.37-0.6.8
ADSL Driver Version A2pB021g.d19b
Wireless Driver Version 3.91.41.0 (Wireless is enabled)
Wireless BSSID 00:16:E3:4C:4C:0B
Ethernet MAC Address 00:16:E3:4C:4C:08
Re: My Opinion
30-04-2009 8:19 PM
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:00:29:39
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 2144 Kbps 448 Kbps
Noise Margin 6.9 dB 9.0 dB
Line Attenuation 63.5 dB 31.5 dB
Output Power 17.2 dBm 12.6 dBm
Re: My Opinion
30-04-2009 8:23 PM
If you're not sure how to get the info then tell us what make/model the router is and we may be able to advise on how to get the information.
Re: My Opinion
30-04-2009 8:50 PM
Thank you all for taking so much interest, and trying to help me as much as you can regarding the speed I am getting at the moment.
My router is the one sent by Plusnet when I first register a: BT Voyager 2091
Broadband Line Status
Latency Type Interleave Line Up Time 00:01:06:09
Line Rate 960 Kbps 448 Kbps
Noise Margin 9.8 dB 13.0 dB
Line Attenuation 63.0 dB 31.5 dB
Output Power 15.6 dBm 12.3 dBm
Internet Connection
PVC Name VPI/VCI Category Protocol NAT QoS WAN IP
Address Status/
Online Time
pppoa_0_38_1 0/38 UBR PPPoA
VC/MUX On On ****** Up
00:01:06:40
Traffic Statistics
Interface Tx packets/Errors Rx packets/Errors
Tx bytes/Drops Rx bytes/Drops
Ethernet 4/0 0/0
256/0 0/0
USB 0/0 0/0
0/0 0/0
Wireless 20361/1 16968/0
15214593/0 5326518/0
WAN 14860/0 18136/0
5453856/0 14610336/0
Thank you all once again!
Frangal
[Moderator's note by Jim (Oldjim) IP address removed ]
Re: My Opinion
30-04-2009 9:02 PM
Re: My Opinion
30-04-2009 9:35 PM
Quote from: Oldjim As a quick check can you advise what this says https://portal.plus.net/my.html?action=data_transfer_speed
Hi OldJim
this is what it says:
High-speed Broadband
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed: 500
The only problem OldJim, is that the 500 used to be 1000 a couple of month back, then went to 750, and now 500.
I must admit OldJim 0.5 Mbs it's quite rubbish, specialy when I am paying for 8Mbs, and lets not mention that I live
in a Cable (Fibre Optic) ready street. I decided to give my money to PlusNet, rather than that give it to Virgin, or it's
owner, who I cant look at even in a picture.
Re: My Opinion
30-04-2009 9:43 PM
Did you do this or has it just lost synch by itself
Can you try the router plugged into the test socket - the part behind the removable lower half of the master socket and report the Broadband Line Status (we don't need the remainder)
Re: My Opinion
30-04-2009 10:26 PM
Regarding what you are telling me to do with the phone socket I wont dare doing it right now, cos' everyone is sleep
and I need to move furniture about, it's abit late for that, so maybe tomorrow I will try, but I have done it before when I
was with Sky and there was no problem with the socket. One thing is that I also have conected to the phone socket the
Sky box (well not to the socket, but the ADSL filter)
Re: My Opinion
01-05-2009 9:21 AM
Depending on the results we may need to carry out some more tests
Re: My Opinion
01-05-2009 11:53 AM
Thank you
Re: My Opinion
01-05-2009 11:59 AM
make sure its just your router plugged in with no phones or sky
Quote Statistics Downstream Upstream
