My Network Name
johni
My Network Name
Why does my PC Ethernet connection show public network: BTHub3-93N3 2
And my Router show Wi_Fi network PLUSNET-8GM8XC?
John I
2 REPLIES 2
Fixes: 160
Re: My Network Name
Hi John,
A warm welcome to the forums.  Interesting question!!  Which router PN Hub One (which implies a fibre service)?
Plusnet routers are unfortunately rebadged BT Hubs at least one generation behind those current distributed by BT Retail (rather looks like big brother's last year's unsold stock hand-me-downs).  I would suspect that although the WiFi SSIDs have been branded Plusnet the internal router name still bears its native BT branding.
As for "Public Network" that is only to do with how your PC considers the network ... not how it actually is.  Whilst your PC treats the network as being public, you might find connecting to other devices on the network difficult - certainly you will not be able to connect to any file shares or media servers on your PC.
bobpullen
Fixes: 316
Re: My Network Name
Are you using Powerline adapters? If you are, my money is on you inadvertently connecting to somebody elses router.
