My Internet seems to only be connecting at 10mbs? Yet my line supports higher speeds
Jiggerjay
I've been with plus net for a few months since swapping over from topcashback, the whole situation is already a mess as the cashback got declined but that's another situation. My Internet is painfully slow. I am suppose to be on 70mbs but I am only connecting at 10mbs. I've tried various remidies on the router and that hasn't helped. I only have one line into the house, I haven't had "quick" Internet since installing it. I've done a bt check and it says the line should be on 80mbs, I've tried everything on my end
33 REPLIES 33
Fixes: 334
Re: My Internet seems to only be connecting at 10mbs? Yet my line supports higher speeds
@Jiggerjay Welcome to the forums. A little more information would be helpful, but:-
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
We could do with a bit more information - especially the section which is cut off at the bottom of your second screen grab.
Jiggerjay
Hello John thanks for the advice, I don't have a phone at all! I haven't had one since I moved into the house seven years ago as we are all mobile here.
Fixes: 334
That is a bit of a problem - unless you move to Full Fibre (which appears to be available), a cheap corded handset is a very useful tool in these circumstances.
As a point of interest, do you have desktop/laptop - because of their screen size, mobiles are not a great help in trying to diagnose potential issues.
Jiggerjay
Hey John I'm on fibre, I think I posted on the wrong forum! Total newb here
Jiggerjay
And yes I have a laptop, I tried connecting via the ether net to the router and it was still 10mbs maximum
Fixes: 334
@Jiggerjay You are on Fibre To The Cabinet  FTTC (Not Full Fibre or FTTP) . However, your connection speed is horrendous - we need to try and determine why.
Fixes: 334
In that case, can you use the laptop to provide the following information, please:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Fixes: 532
be interesting to see the broadband stats from the router. Those sync speeds are VERY wrong!
The downstream 9.999Mb looks suspiciously like a 10Mb profile setting , although AFAIK there isnt a 10Mb downstream profile? and 10Mb is not the top of a banded profile , VERY ODD! but the upstream is also WAY below the estimates...
Fixes: 334
Agreed, @MisterW , which is why I posted the request for the full details.😉
Jiggerjay
Hey John, I did the DSL test above (images in first post) just did the other test with my laptop collected to the router directly
Jiggerjay
I have the technical log from the router, shall I post here?
Fixes: 334
@Jiggerjay Fair enough,  but that original screenshot was missing important information, which is why I requested it from the laptop, along with further data. I am aware you can't, unfortunately, do the phone test.
Fixes: 334
Yes, but obscure any personal information.
Jiggerjay
Attached, thanks for your speedy responses.
