My Broadband Speed
- Re: My Broadband Speed
My Broadband Speed
01-06-2012 2:01 PM
For some time now My Broadband Speed has been displaying the following message:
It appears to be running perfectly OK to me and the results are in line with Speedtest.net. Can someone from Plusnet please comment on whether the fault has been corrected or not and, if so, see about having the message removed.
Quote Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.
Message 1 of 8
(1,891 Views)
7 REPLIES 7
01-06-2012 3:05 PM
Message 2 of 8
(688 Views)
01-06-2012 3:26 PM
Also if you hit it at a time when a number of other people are also running tests it gives a pretty bad result.
Message 3 of 8
(688 Views)
01-06-2012 5:26 PM
OK. Thanks for the replies.
Message 4 of 8
(688 Views)
01-06-2012 5:53 PM
So why couldn't the message be a bit more specific then instead of giving everyone the impression it's completely borked. Everytime I've run it, the results are what I would have expected.
Message 5 of 8
(688 Views)
06-06-2012 9:03 AM
Same here. It is so convenient for the rest of us to use, at the bottom of the Forum pages, that an amended notice to say that it is workable below 40MB and at busy times (suggest what these are found to be) would be helpful.
Message 6 of 8
(688 Views)
06-06-2012 9:13 AM
'busy' is whenever several users with fast connections are running a test at the same time. You can make software do most things but being psychic to know when the overloads are going to occur isn't one of them. Any period defined as not being busy would be vulnerable as users would be likely to run tests soon after the period started.
Message 7 of 8
(688 Views)
07-06-2012 8:22 PM
Doesn't stop the message from saying when under heavy load or similar, that'll be upto the user to assess when it is, by doing comparisons, and it's also a bit obvious that it won't be that busy at 0300 or similar!
Message 8 of 8
(688 Views)
