My BroadBand Speed (The Speed Tester)
- My BroadBand Speed (The Speed Tester)
01-11-2007 12:42 PM
Re: My BroadBand Speed
01-11-2007 12:51 PM
That's a rather confusing thread title
http://www.mybroadbandspeed.co.uk/ is working fine for me from here.
Re: My BroadBand Speed (The Speed Tester)
01-11-2007 12:54 PM
01-11-2007 1:19 PM
I had someone raised a problems to networks on it last week? Seems it's inaccessible from blueyonder connections?
Fancy finding it for me James?
Ex-Broadband Service Manager
01-11-2007 1:21 PM
01-11-2007 2:58 PM
Quote from: Kelly I (still) can't access it either.
Kelly, what's your IP address and what DNS servers are you assigned when you're connected?
The problem ID is 47661 by the way.
01-11-2007 3:11 PM
01-11-2007 3:26 PM
Quote from: Kelly I had someone raised a problems to networks on it last week? Seems it's inaccessible from blueyonder connections?
Not working from JANET / University of Gloucestershire connections either. Tried both from my room in halls and over the university wifi in the student union.
My IP is 193.61.84.99
DNS is 10.58.255.251
01-11-2007 3:32 PM
Glasgow Cale Network on JANET:
Ethernet adapter Local Area Connection 3:
Connection-specific DNS Suffix . : enterprise.gcal.ac.uk
DHCP Server . . . . . . . . . . . : 193.62.224.207
DNS Servers . . . . . . . . . . . : 10.1.1.75
10.1.1.76
10.1.1.77
Primary WINS Server . . . . . . . : 193.62.224.10
Secondary WINS Server . . . . . . : 193.62.224.9
Extenal IP: 193.62.251.32
NSLOOKUP Returns:
H:\>nslookup www.mybroadbandspeed.co.uk
Server: itsdc1.enterprise.gcal.ac.uk
Address: 10.1.1.75
Non-authoritative answer:
Address: 84.92.1.14
01-11-2007 3:50 PM
01-11-2007 3:57 PM
traceroute to www.mybroadbandspeed.co.uk (84.92.1.14), 64 hops max, 40 byte packets
1 192.168.0.1 (192.168.0.1) 1.729 ms 0.948 ms 0.803 ms < My Airport Express
2 10.53.1.254 (10.53.1.254) 1.855 ms 4.394 ms 22.915 ms < University Gateway Router
3 * * *
4 * * *
5 * * *
6 * *
For comparison a Tracert to google comes up the same, so I doubt the tracert above will be of much use...
traceroute: Warning: google.co.uk has multiple addresses; using 216.239.59.104
traceroute to google.co.uk (216.239.59.104), 64 hops max, 40 byte packets
1 192.168.0.1 (192.168.0.1) 16.664 ms 21.291 ms 23.901 ms < My Airport Express
2 10.53.1.254 (10.53.1.254) 2.711 ms 1.798 ms 9.485 ms < University Gateway Router
3 * * *
4 * * *
5 * * *
6 * * *
01-11-2007 4:40 PM
01-11-2007 5:13 PM
01-11-2007 8:28 PM
I will test the speedtster tomorrow in uni and check to see if its working for me!
02-11-2007 1:36 AM
