Multiple invalid flags showing in router; speed dropped from 2.5mb to 1.8
Fixes: 160
Re: Multiple invalid flags showing in router; speed dropped from 2.5mb to 1.8
Well as dusk arrives, the snrm will dip.
The issue is when you resynch the line will go as fast as it can at the target snrm which on a normal line is 6dB.
If the last resynch was during the hours of darkness the previously reported snrm of 7.6dB is very explainable.  If it was during daylight hours, then it is a bit odd.  Keep watching it through the switch to ADSL2 or a resynch - you might get more speed yet.
Upload might be better too.  You will just have to wait and see what the adsl2 dlm makes,of the line.
Gel
Aspiring Champion
Fixes: 29
Tks; the 7.6 reading was @ 15.19.
On ADSL2  as I'm 3.7 miles from exchange, gather improvements in my location, may be marginal.
Fixes: 160
2.4Mbps.  For CN20 your current speed is right on the nail.
