Multiple invalid flags showing in router; speed dropped from 2.5mb to 1.8
Gel
Seasoned Pro
Fixes: 14
Fixes: 19
Re: Multiple invalid flags showing in router; speed dropped from 2.5mb to 1.8
Hi Gel,
I'm sorry to see this, what is your connection like today?
 Ben Babinski
Gel
Seasoned Pro
Fixes: 14
Here's stats; prior to 2pm yesterday, when Interweb went down my new Plus Net Hub One router had performed flawlessly for over 30 days ie since I first installed.
I see it also seems to have gone down yesterday @ around 10pm too.
Speed around same as original post unfortunately; I'm on a long line from exchange at end of our village.
Exchange THCY- a 20CN one.
In past have occasionally achieved over 3mb.. just Smiley
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ54605093
3. Firmware version: Software version 4.7.5.1.83.8.217.1.1 Last updated 13/02/16
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 13:32:14
6. Data rate: 448 / 1888
7. Maximum data rate: 1000 / 2048
8. Noise margin: 18.0 / 13.4
9. Line attenuation: 31.5 / 60.2
10. Signal attenuation: 31.5 / 56.4
11. Data sent/received: 51.9 MB / 548.7 MB
12. Broadband username: 888888@plusdsl.net
13. 2.4 GHz Wireless network/SSID: B8888
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 300 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: 2
17. 5 GHz Wireless network/SSID: B88888
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 84:a4:23:04:ae:70
23. VPI/VCI: 0 / 38
24. Modulation: G.992.1 Annex A
25. Latency type: Interleaved
26. Software variant: AA
27. Boot loader: 1.0.0
Gel
Seasoned Pro
Fixes: 14
speed dropped from 2.5mb to 1.8 now 1.4....
Today's stats even worse , as attachmentSad
Would you recommend I reboot via Hub s/ware to try & achieve better speed?
Tks.
UPDATE
Multiple disconnections in last 3 hours; finally re established broadband but at only speed as below Sad
. DSL uptime: 0 days, 00:04:29
6. Data rate: 448 / 1472
7. Maximum data rate: 988 / 1632
8. Noise margin: 18.0 / 14.8
9. Line attenuation: 31.5 / 61.0
10. Signal attenuation: 31.5 / 59.2
Gel
Seasoned Pro
Fixes: 14
Ben, no reply to my response (to you)  still; can you look at a SNR reset to boost my current poor speed pse?
Hoping to get back to 2.5mbps which is best I can hope for from current.
Tags (1)
Gel
Seasoned Pro
Fixes: 14
Router connection stable for over 4 days now, but at 1.6mbps on router stats, 1.2 when measured on adsl.org www.
I am wondering whether I should do a soft router reboot to see if I connect at better speed or to hang on and wait for BT DLM to correct..eventually  back to 2.5 as I had been seeing on router previouslySmiley  BenB: any responses for me?
Fixes: 186
Hey @Gel, apologies for @BenB's delayed response.
I'll get a reset put through on your line shortly, however I've also noticed 21CN is available, which should give a little improvement on speeds and will mean that the speed profile updates a little quicker when you do run in to re-syncs.
 Harry Beesley
Gel
Seasoned Pro
Fixes: 14
That must be new as exchange checker shows:
THCY; BT have not advised a planned date for WBC on 21CN
Have just found I can't currently log into my router either- incorrect p/word.
 (Admin P'word was changed by me at outset) ; is there someone working on my issue that could have affected my PlusNet Hub one?Huh
Fixes: 186
Your account is showing a disconnection at 14:27, which matches up around the time I'd put the SNR reset through, however it also shows that you reconnected almost immediately
Are you still offline?
Mis-read what you'd said. It shouldn't have caused any problems logging in to the router.
 Harry Beesley
Gel
Seasoned Pro
Fixes: 14
Right just got back in & successfully logged in to router and your reset has worked wonders; thanks Smiley
5. DSL uptime: 0 days, 00:30:52
6. Data rate: 448 / 2336
7. Maximum data rate: 924 / 2336
8. Noise margin: 18.0 / 7.6
9. Line attenuation: 31.5 / 60.9
10. Signal attenuation: 31.5 / 59.7
Speed Test however shows no real difference Sad
http://www.thinkbroadband.com/speedtest/results.html?id=14610795975739441898
Fixes: 186
Disconnect and reconnect and that should be sorted now.
I've manually updated the profile on our side so you're not waiting for it to come through from our suppliers. That should also update quicker when you're order for 21CN completes Wink
 Harry Beesley
Gel
Seasoned Pro
Fixes: 14
Thanks again; any idea on 21CN timescale as no info on PN Exchange Checker; is there another www to check?Huh
Fixes: 186
DSLchecker shows it's available Wink
The order is due to complete on 25/04/16 Smiley
 Harry Beesley
Fixes: 26
Though you've marked this as fixed the snrm of 7.6dB is somewhat higher than it should be.  Keep a watch on things when the ADSL2 order goes through.
Gel
Seasoned Pro
Fixes: 14
Just rechecked, and lowerSmiley
Will I get better upload speed when changeover made?
8. Noise margin: 18.0 / 6.2
