Moving house :Plusnet speed offer is much slower than BT and others
Legend
Fixes: 294
Re: Moving house :Plusnet speed offer is much slower than BT and others
@FirefishHR wrote:
But a family member moved to a location in Kent. The person moving out had BT and good speeds 66/18   (and screenshots to prove it)   Then when they moved in and used Plusnet they only got 30/8 ..   Mad because its the same infrastructure and hub
That again makes no sense - if the line was capable of 66/18 for the previous people with BT, it is still capable of 66/18 with PN.
Mustrum
Fixes: 79
It is only capable of those speeds if connected to the nearest FTTC cabinet - if it was out of capacity when FTTC was ordered Openreach will connect it to another if they can rather than upgrade the optimal cabinet - or indeed many other reasons.
Proof is in the pudding - or more accurately, enter the phone numbers in the BTW DSL checker and show us the results.
pjmarsh
Fixes: 23
One thought (which could be total rubbish!), are those estimates for the annex based on old data.  Maybe some network reconfiguration has since happened (infill cabinet or something maybe), and the main house estimates have been updated based on observed speed, but the annex hasn't because it didn't have a broadband service.  I note the lack of observed speed section in the screenshot.
Fixes: 430
I think that following this suggestion would help:
@Mustrum wrote:
@FirefishHR   to get a more accurate picture of the differences are, if you do the same thing again with the DSL checker, but use the phone numbers, and include the exchange and cabinet number - obscure the number though - it may be that they are fed from different cabinets - certainly that one is more than 20 yards away.
Just because the two lines come from the same pole does not mean that they are detinitely connected to the same cabinet. Annexes may well be built and the extra phone line installed decades after the original phone was fitted. you don't know what's happenened to the wiringupstream to the property in the meantime. .
