Moving home - Unlimited Fibre Extra to Unlimited broadband 10 months remaining on contract Options?
bex552
Current house I have unlimited fibre extra with 10 months left on my contract, will be moving in the next month to new house which postcode checker is telling me I can only get Unlimited broadband, the speeds are way to slow due to the need of working from home. What are my options? Currently pay £25.13 per month. Any help much appreciated, thank you
23 REPLIES 23
Fixes: 334
Re: Moving home - Unlimited Fibre Extra to Unlimited broadband 10 months remaining on contract Optio
@bex552 The postcode check is not that reliable. Do you know the current phone number of the property you will be moving to?
bex552
I do know the number yes, and when i put that in the checker too its still coming up t he same, broadband only
Fixes: 334
OK, @bex552 , can you post a screenshot of that page - I wonder if you are moving to a Full Fibre priority exchange area?
Fixes: 459
@bex552
Have you checked to see if WBC FTTP is available?
If not it’ll probably be the choice between taking the slower service or paying the cancellation charge.
bex552
Fixes: 334
@bex552 Not quite what I was expecting - can you post the result of: BT Broadband , obscuring the phone number?
bex552
Apologies, I have edited
Fixes: 334
Yuk, @bex552 - That is definitely not good, but that is all you are going to get. Out of curiosity, which exchange is it on?
bex552
Fixes: 334
I don't know the area, but looking at that, it must be VERY rural.
Would you consider Virgin - If it WAS available?
bex552
Thats the annoying thing it really isnt! It is classed as a village but it is one of uks biggest! Where i currently live has a similar population which is why i dint think i would have a problem! Its only 4 miles away from cheltenham!
bex552
Yes i would consider virgin, the only problem with that is they are not sure the house can get virgin either, they have to send an engineer out to check!
Fixes: 334
Unfortunately looks like you are stuck, then. 😥
Fixes: 334
If others in the area (local streets) can, then the chances are you may be lucky - all depends if your street has been cabled. Virgin should know this without having to send out an engineer.
