Moved within Winchester - still seem to have the same line profile
Mansn
Hello there, we recently moved. Our PlusNet connection came with us and the exact same speeds seem to persist even though we were quoted line speeds of up to 18 Mbps. I think something might be amiss, as originally our connection was supposed to be activated on Tuesday, but when we moved in on Saturday I plugged everything in and it all worked. We even had a BT engineer come and visit to 'install the line' even though this wasn't needed (I called, but due to the bank holiday weekend you were not able to do anything about it).
So here are my router stats:
Link Information
Uptime: 1 day, 21:54:40
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 10.0 / 17.0
SN Margin (Up/Down) [dB]: 22.0 / 8.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 75 / 0
Loss of Signal (Local/Remote): 334 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 715 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 3 / 119
HEC Errors (Up/Down): 0 / 89
Here is the information from the member's centre page of Plusnet:
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
21 Mb
And this is our actual line speed:
Still the same old 3 Mbit connection as always! Is there any more information you require to have a look at this?
Re: Moved within Winchester - still seem to have the same line profile
http://speedtester.bt.com/ and see what the IP Profile is at, for once more than likely BT's is set to 3mbit
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Mansn
These are the results:
1. Best Effort Test:  -provides background information.
Download  Speed
2.88 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.88 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
My router is getting pretty old now. I must have received it around 4 years ago now. Can it even go up to 16 Mbit? It's a Thomson TG585 v7.
Fixes: 62
It looks as though you have either been provisioned on 21CN on ADSL1 or 20CN but from your BT speed test where there isn't an upstream speed test you are probably on 20CN
Either phone in or wait for it to be picked up here
Mansn
I called in and the guy just said that my line stats are learning or something along those lines.
I hope that one of the people from Plusnet can have a look at my account through the forum. They have always been really helpful in the past.
Hi Mansn,
I've checked your account, you have an order is progress to regrade you to ADSL2+, this will complete on the 6th September. Once this is complete you will then see your speed increase.
Your router should work fine and there will be nothing you need to change internally.
Let me know if come the 6th September your still having any issues.
I think my colleague might of been referring to the training your line will go through, this will last for upto 10 days when regraded. This will help identify the ideal settings for you line to perform at it's peak.
Chris
Mansn
Hello Chris, thanks so much for clarifying this with me. I can't wait until 6th September! I'll let you know how it goes.
Many thanks for the prompt response!
Fixes: 62
In preparation for that and to ensure the best speeds can you check your internal wiring - the reason for that is that I would have expected a higher noise margin on 20CN with your attenuation.
Can you plug the router into the test socket and report the stats again. If there is a significant increase in the noise margin it would be worth while investigating further
This explains it
Mansn
just plugged it into the master test:
Link Information
Uptime: 0 days, 0:01:23
Line Attenuation (Up/Down) [dB]: 10.0 / 16.0
SN Margin (Up/Down) [dB]: 24.0 / 9.0
Loss of Framing (Local/Remote): 86 / 0
Loss of Signal (Local/Remote): 335 / 0
Error Seconds (Local/Remote): 726 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
And again in the 'normal' socket:
Much faster already!  Cheesy
Fixes: 62
Not much difference in the stats - so you can now wait in anticipation  Grin Grin
Fixes: 68
Glad to see things are on the up so far, let us know if you have any further concerns after the 6th.
 Adam Walker
Mansn
Hi there, I have restarted the router this evening:
Link Information
Uptime: 0 days, 0:01:21
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 15,900
Output Power (Up/Down) [dBm]: 11.5 / 21.0
Line Attenuation (Up/Down) [dB]: 8.0 / 17.5
SN Margin (Up/Down) [dB]: 27.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
FEC Errors (Up/Down): 1 / 0
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 177 / 1
However my speed seems to have dropped the last couple of days to around 5.5 Mbit.
Speedtester results:
Still a bit slow isn't it?
Fixes: 10
Go to https://portal.plus.net/my.html?action=stable_rate and check what it says for your current line speed. If it doesn't say 14000 by tomorrow morning ring up Plusnet and ask for it to be corrected.
Don't be tempted to reboot the router - it won't help and could actually make things worse.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mansn
The page says:
Current line speed:
5.5 Mb
I rebooted the router as the stats in the router were not reporting the 15,900, but still the 8,000 or whatever on the downspeed. After the reboot that went up.
Fixes: 10
That one reboot was fine (and probably needed), just don't do any more.
