Moved to Pro, Speed doubled for a week then dropped back down again
- Moved to Pro, Speed doubled for a week then droppe...
18-04-2011 11:02 PM
Hi, I recently moved to Broadband Pro and was quite pleased with the increase in speed I received :-
However my speed has now dropped back to what I was getting before I was on Pro :-
I have run the BT speed tester:-
Download speedachieved during the test was - 6649 Kbps
For your connection, the acceptable range of speedsis 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :15323 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 13519 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.24:31.86:49.91 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Is there anything that I can do about this or should I raise a ticket?
Message 1 of 3
(679 Views)
2 REPLIES 2
Re: Moved to Pro, Speed doubled for a week then dropped back down again
19-04-2011 12:18 AM
Well you're throughput is bad
the actual IP profile and sync speed looks great what does you're Plusnet IP profile Say?
Message 2 of 3
(369 Views)
19-04-2011 12:28 PM
HI RobAllen,
There's no restrictions on our side, your profile is still 13000. Speed changes have nothing to do with package changes so it's not that. Have a look here for some tips on troubleshooting the issue.
Jojo
Jojo
Message 3 of 3
(369 Views)
