Moved to ADSL2 - How Long For IP Profile To Increase?
- Re: Moved to ADSL2 - How Long For IP Profile To In...
06-07-2011 12:41 PM
I was moved on to ADSL2 about 24 hours ago. My sync speed has been steady at 17,326 but my IP Profile is still 7,150. How long will it be before the IP profile is updated and I can benefit from the increased speed?
For info, the BT Speed Test gives:
Download speedachieved during the test was - 6555 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :17326 Kbps(DOWN-STREAM), 439 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Thanks - Bob
Re: Moved to ADSL2 - How Long For IP Profile To Increase?
06-07-2011 1:28 PM
... the IP Profile is not updated on a real time basis. BT take your lowest downstream synchronisation speed over a three day period and then assign the appropriate IP Profile.
I guess I'll just have to be patient !!!
Bob
06-07-2011 6:40 PM
To achieve a 17mbps sync you must have a pretty good line so I would expect a better profile to be assigned within 24-48 hours but BT would insist on waiting for the full 10 day training in period for any fault to be reported.
06-07-2011 7:20 PM
Bob.
07-07-2011 8:20 AM
Just to clarify the 10 day fault rule. Does this mean that if my IP Profile remains at 7,150, we won’t be able to do anything about it until 10 days have elapsed?
Bob
07-07-2011 8:37 AM
Sounds like your profile might be 'stuck'. I'm pretty sure mine increased almost immediately when I got moved to ADSL2+. My synch went from 8Mb to about 14Mb. I noticed one morning that my Linux updates seemed to be going a bit quick, about 1.2MB/Sec, and thought, 'hang-on how's that possible on an 8Mb connection?'. I looked at my router logs and it had resynched the previous day at 14.5Mb!!! and my IP Profile was now 12Mb.
07-07-2011 8:45 AM
Not quite so seamless for me. I was at home on Tuesday (when the switch happened) and noticed that my VOIP phone had gone off-line. Further investigation revealed that I’d completely lost my broadband. Support suggested turning off my router for a couple of hours and when I switch it back on in the evening I had a 17,326 sync but my IP profile has been 7,150 ever since.
It’s not an issue, (I’m still getting all the speed I need), but I’m the type of person who like to understand what’s going on and what to expect
Bob
07-07-2011 8:59 AM
Quote from: bobboulby Does this mean that if my IP Profile remains at 7,150, we won’t be able to do anything about it until 10 days have elapsed?
We can perform an SNR reset whenever we want, but we wouldn't be able to raise a fault in the first 10 days. I'd say give it a solid 3 days (sync) and reboot, if no joy just let us know and we'll perform the reset.
07-07-2011 9:08 AM
Just for my own understanding what does a SNR ratio reset do? I’ve currently got a downstream SNR of 6db and I wouldn’t really like it to go any lower than this. I’d much rather have a stable connection then trying to squeeze the last bit of speed out of it.
Bob
07-07-2011 9:18 AM
After the switch, my connection retrained a few times in the first 2/3 days to try and establish a stable speed. Since yours appears to be quite stable, I wonder if a 'delta' report ( when the sync speed changes ) has somehow gone missing on BT's systems and it hasn't seen the change to 17M.
Don't worry though, if Ben's on the case he'll sort it out.
07-07-2011 9:32 AM
Jojo gave it a good kicking though.
Somebody give this PN profile a kick for the poor guy!
Jojo! are you wearing your steel toecaps today?
07-07-2011 9:38 AM
Quote from: grudkin Jojo! are you wearing your steel toecaps today?
She only wears those when on an 'educating' trip to CSC
07-07-2011 9:46 AM
I even heard Jojo drives to work in a Challenger Tank!
Some even say that Jojo dated the Stigg at school!
07-07-2011 12:17 PM
FWIW, I was switched to ADSL2+ on Monday and my profile seems to have been lifted today, i.e. it took pretty well the full 72hrs. (I say 'seems' to have been lifted because the BT Speedtester, having worked consistently over the last two days to confirm the profile was unchanged, now seems to have gone on the blink again)
Hopefully, you will see an uplift in the next 24hrs.
Trevor
07-07-2011 12:48 PM
Quote from: bobboulby Just for my own understanding what does a SNR ratio reset do?
It returns DLM to it's default settings (6dB downstream, etc.) and forces it to recalculate target SNR margins and various other profiles. One of the uses (as may be required in your case) is to bring it out of a 'stuck' state and allow profiles to move automatically.
