Moved house but speed is far lower than sync.
- Moved house but speed is far lower than sync.
08-10-2014 5:31 PM
I moved my broadband and phone on Monday to another house, and while it's currently syncing at 16775 the throughput is as bad as it used to be at the old house. Maximum download speed from any source (HTTP or NNTP) is around 175KB/s. Could I be stuck on a low speed profile somehow? The line has not disconnected overnight, so I don't think DLM is running.
MODEM STATS
BT TEST:
MODEM STATS
Link Information
Uptime: 2 days, 0:09:16
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 16,775
Data Transferred (Sent/Received) [GB/GB]: 1.22 / 14.89
Output Power (Up/Down) [dBm]: 12.3 / 0.0
Line Attenuation (Up/Down) [dB]: 11.8 / 29.5
SN Margin (Up/Down) [dB]: 32.1 / 5.8
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1,578 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 9,516
HEC Errors (Up/Down): 0 / 69,961
BT TEST:
1. Best Effort Test: -provides background information.
Download Speed
1.25 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.25 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.8 Mbps
Upload Speed
0.32 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.32Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Message 1 of 5
(874 Views)
4 REPLIES 4
Re: Moved house but speed is far lower than sync.
08-10-2014 5:38 PM
what does this say https://portal.plus.net/my.html?action=data_transfer_speed ?
Message 2 of 5
(537 Views)
08-10-2014 8:22 PM
Estimated line speed:
Current line speed:
1.6 Mb
Current line speed:
1.6 Mb
Message 3 of 5
(537 Views)
08-10-2014 11:56 PM
Spoke to support on the phone this evening, turns out we were artificially limited to 1.6. The tech lifted this and one reboot later I have a 15Mb connection
Although, the current line speed page now says it should be 21Mb. Does that seem attainable with my stats?
Message 4 of 5
(537 Views)
09-10-2014 8:16 AM
That's the default value until proper reports come through from BT. It should be the same as your IP Profile (slightly rounded down).
Message 5 of 5
(537 Views)
