Moved a day early
- Re: Moved a day early
Moved a day early
18-09-2009 12:35 PM
The cutover was due for tomorrow, but looks like I've been done today
anything else needs to happen ?
ADSL Link Downstream Upstream
Connection Speed 12541 kbps 855 kbps
Line Attenuation 27.5 db 16.4 db
Noise Margin 6.6 db 6.0 db
Message 1 of 4
(936 Views)
3 REPLIES 3
18-09-2009 1:00 PM
nope just cross your fingers that the DLM makes friends with you if your running XP then checking and updating your RWIN with DrTCP might be a good idea with your increase in download
me and my DLM fell out many months ago as many others have to.
I would of thought you should be able to get the upsync near to 1mb thoe at your line length. am currently synced at 859kbps up on 51db atten.
but i would leave well alone an resist doing resyncs where it's not nessary dont want the DLM geting it knickers in a twist
Message 2 of 4
(403 Views)
18-09-2009 1:22 PM
Nothing you need to do at all.
It's probably safest not to reboot
I've got a Community Library article on ADSL2+ DLM which is about 80-90% finished, which hopefully you'll be able to see later on today.
Message 3 of 4
(403 Views)
18-09-2009 1:43 PM
Well it's just dropped and resync'd at
Connection Speed 12835 kbps 855 kbps
Noise Margin 6.6 db 5.9 db
Message 4 of 4
(403 Views)
