Most web sites ok, some not opening normally, but available by vpn?
michaelrmgreen
Most web sites work normally, but some don't open, the connection eventually goes to http://failed.billing.plus.net/apps/payment/failed. The browser error is in the form of a time out error rather than a site not found error. I know these sites are up because one of the 'Is my site down' sites shows them as up and I can access the sites using a vpn. Can someone suggest how I can diagnose this problem?
example:
bbc.co.uk
barbarasummers.net
5 REPLIES 5
Fixes: 128
Re: Most web sites ok, some not opening normally, but available by vpn?
Which router are you using?
If TG582n are you using Win10?
If yes to both, when you experience these issues, try pinging the failing URL and post here the IP address returned by ping.
OskarPapa
Fixes: 64
Hi @michaelrmgreen, thanks for your post.
We're sincerely sorry to hear of your connection woes.
The message that you're seeing is usually seen when there is an outstanding balance on the account, although you should be able to click 'acknowledge and continue browsing' at the bottom of the page.
Have you had a chance to review the latest bill as of yet?
Fixes: 128
@michaelrmgreen
When you say...
Do you mean that page actually loads, or is it that page which times out?
Do you have active payment details (a DD or card details) recorded on the account?
Are you using safe guarding?
Do you have a fixed IP address?
Have you encountered the failed billing situation in a previous month … and had the restriction removed?
@OskarPapa
Only if the page actually loads (there have been a few reports of that page timing out and at least one refused a connection) … and even after that there have been reports of there being no continue browsing option.
michaelrmgreen
Router = F2704N
OS = Linux Mint XFCE 64
ping results = 100% packet loss, both in the Plusnet network and elsewhere.
The
page never opens, I get a time out message. I do have funtional payment arrangements, although I had a problem in the first month but that was resolved.
No, I'm not using Safe Guarding as far as I know (How to check?).
As far as I know I have a dynamic ip address.
Most sites seem to work ok now including bbc.co.uk, although, ironically, community.plus.net is very slow, but barbarasummers.net is still not available.
In Firefox the browsers stops at failed.billing... with a time out message. In Opera I get an ERR_CONNECTION_RESET error
barbarasummers.net works normally via VPN, where I work and at assorted free WiFi venues.
Can anyone suggest a way to investigate what is going on? Thanks.
OskarPapa
Fixes: 64
Thanks for getting back to us @michaelrmgreen.
I can't divulge precise billing information via the forum but can confirm that it does appear to be the 'failed billing' restriction that keeps reapplying to the account. This would usually keep applying if there were an outstanding balance, for example.
I've just sent you a ticket with further information here.
Please let me know via this thread if you respond to the ticket so that I can take any further action necessary on the account.
@Townman - spot on, thanks for the assist.
