Most engineers ever involved? DSL speed issues progressed to line disconnection - Still not solved!
- Most engineers ever involved? DSL speed issues pro...
Re: Most engineers ever involved? DSL speed issues progressed to line disconnection - Still not solv
25-05-2018 10:15 AM
Is there any update on this?
25-05-2018 10:41 AM
25-05-2018 1:09 PM - edited 25-05-2018 1:09 PM
Thanks for updating your ticket.
I've booked the appointment in for Monday AM.
Unfortunately my annual leave has come around at a bad time, as I'll be out of the office tomorrow until the 5th June. I was hoping this would be resolved by now.
I'll be handing this over to one of my colleagues to monitor closely and provide you with updates.
25-05-2018 2:03 PM
I've moved the ticket on your account to @SammyM's ownership.
She'll keep you updated there and here.
31-05-2018 10:59 PM
So, another engineer - 3 in fact, this time. Over 3 days, where once again I had to be in.
No resolution, no actual line improvement but a rather obscure entry in the question:
===Ring ahead information ends===
I cannot complete this task because Further investigation by adsl senior engineer as other lines in same area are getting similar errors .pqt outside prem perfect but lots of errors.senior engineer looking at fault and investigating at. Please pass to CSS
No update for a day since this. I do understand that Anoush has been allowed a well earned break, however, we have no conduit to follow up on this call apart from through Plusnet. Please can we have an update and a plan for resolution.
Cheers,
Allan.
31-05-2018 11:34 PM
Just out of interest, I have found the counters for nCodeViolations and nFECErrors, which are graphed below. This is per 15 minutes.
01-06-2018 12:16 PM
Hi Allan,
I can see we're waiting for a further update from the operational manager at Openreach and we've been advised to expect that by 14:00 on 4/6.
Sammy has ownership of the issue and will update you with anything further we can add as soon as posisble.
02-06-2018 12:46 PM - edited 02-06-2018 12:57 PM
Thanks for the update.
I finally have a reasonable way to graph code violations + FEC errors - the graph below is a 60 second (approx) rolling average of both. The units are errors per second.
It looks like a continuous improvement of the line, but it's not - every "step down" in FEC / CRC errors is a DLM intervention which steps up the bits used for correction.
Hopefully this at least gives me an idea if BT "fixes something". If you look, the DSLAM is doing exactly what it should - as soon as errors/min exceeds 12 or so, the line gets punted downwards.
03-06-2018 10:02 AM
So, when Monday rolls around, we'd just better hope that they happen to be in a "erroring" time, otherwise no fault found, job done, closed.
Damn you, intermittent faults.
03-06-2018 12:41 PM
04-06-2018 10:28 AM
Good idea! Attached.
04-06-2018 10:33 AM
Looks like there's a moderately consistent peak or dip (change) around 12-2pm. I think the time axis is slightly off here - not sure which way without applying some thought.
04-06-2018 3:08 PM
Hi @Dibblah,
I'm sorry that this issue is still ongoing and for the inconvenience that this has caused.
Our suppliers requested a detailed report from the local operations manager yesterday but they have been advised that he is now on leave. In the meantime they have requested his covering engineer provide the information. We're due a further update tomorrow and will be in touch once we've recieved this.
Sorry that we've not been able to get a more constructive update today for you.
05-06-2018 3:53 PM
Following @EmilyD's response, our suppliers chased this up with Openreach a few hours ago, advising that they've escalated this matter to senior management by e-mail and left them a voicemail message too on their phone.
At the moment, we don't have a constructive update yet but we should know more tomorrow.
06-06-2018 2:57 PM
This morning the DSO team updated our suppliers to advise that the operations manager has asked a senior engineer to discuss this further with a head coach this week, because despite the extensive work carried out by their engineers there's still major issues present on the line. I've been advised we should expect a next update on Friday.
