More teething problems
angushood
Newly set up and connected and now no broadband signal is being detected. Have been struggling with a connection since it first came on but now it won't pick up a broadband signal at all.
Have tried the troubleshooting steps from the booklet but to no avail.
Info from router today:
1 - Product name: Plusnet Router
3 - Firmware version: 7.275.11_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: -
7 - Data rate: 0/0
8 - Maximum data rate: -
9 - Noise margin: -
10 - Line attenuation: -
12 - Data sent/received: 0.0/0.0
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 300 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: Automatic (Smart Wireless)
25 - Firewall: Off
27 - Software variant Version 1.0
28 - Boot loader: 7.275.11
Kind regards,
Angus
19 REPLIES 19
Legend
Fixes: 255
Re: More teething problems
@angushood First question - what router have you got? Second question - what lights/colours are showing?
angushood
Hey there,
Plusnet router - 2704N.
Lights: power-solid, broadband-flashing, internet-off, wifi-solid. All green.
Legend
Fixes: 255
OK. First option, do a power cycle - not forgetting to click the disconnect button on the router first. Second, if that doesn't work, try a factory reset.
angushood
Hey jab,
Tried both of these just now. No change. Still not finding broadband.
Although there wasn't a specific disconnect button on the router.
Marksfish
Seasoned Pro
Fixes: 4
Have you put a filter on a filtered faceplate?
idonno
Champion
Fixes: 6
@angushood If the above doesn't help, are you sure you have your username / password correct. I can recall spending quite some time (about 6 years ago now) trying to get the darn thing to connect, only to find that my username was not as it should be. Might help, might not.
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
Legend
Fixes: 255
@angushood I'm confused, but the comments above by @Marksfish  and @idonno are both valid possibilities.
Mustrum
Fixes: 77
Is your phone line working?
angushood
Hi all,
Filter is in the socket, have no other phone sockets being used anywhere either.
Don't have a landline so can't test however the line was connected on Friday and the engineer tested it in front of me and it worked.
Username. Just found it wasn't correct in the router. So tried the correct ones and still no luck. Correct combination and still flashing. Am i supposed to use my email or will the username sent in the welcome email work? Tried both but wanna be sure.
Cheers
Legend
Fixes: 255
@angushood Your username, without anything else, and the password associated with it, are the correct ones for your router. I assume from your comment that this is a single socket into which you have to plug a filter and not a filtered socket?
I keep saying this, but a cheap corded phone (around £5 from the likes of Argos) is an essential tool for checking the phone-lines quality. However, as you haven't got one, try running the automated test from here: https://www.plus.net/help/phone/phone-line-troubleshooting/
Bogbody
Fixes: 4
Its your user name followed by @plusdsl.net
i.e. username@plusdsl.net
Legend
Fixes: 255
My error, @Bogbody , although I thought that '@plusdsl.net' was pre-filled?
angushood
Hey,
OK. Account details are correct and entered.
Single socket with a filter plugged in. Have tried other filters too but no difference.
Ran the automated test and no faults found.
Legend
Fixes: 255
In that case, I'm stumped, because it appears your router can't connect to the WAN  -at all - which doesn't make sense.
The only thing I can think is that you have a phone problem, despite the automatic test reporting none, but we can only eliminate that if you have a phone to check it with - the automatic test does occasionally report 'n problem' when there actually is one.
