More speed issues
- More speed issues
More speed issues
08-10-2007 10:55 AM
Re: More speed issues
08-10-2007 11:02 AM
This is basically down to how BT profile lines and the fact that you are a long way from the exchange.
After checking your line, I can see that your router or modem is connecting with the exchange at 864Kbps. This is primarily down to the length of your line. You're having your speed profiled by 750Kbps by BT and 500Kbps by ourselves (I've just changed this to 1000Kbps so that you can eek a little more out of your line following a reboot).
Having said all of that, you should be able to get marginally improved speeds, even though your line is a long one. I'd strongly recommend ensuring that you try changing your microfilter over and also to ensure that you are connecting via your master socket. this will ensure that you get the best possible throughput.
There's also a link to a speed faults guide I wrote in my signature, which may be of some interest. I hope this helps in your quest for faster speeds.
08-10-2007 3:03 PM
When having numerous problems with the line itself (Telephone wise) the BT engineer commented that my line wasn't going to the exchange he expected (Near the main gate of the camp) but was going off to a local town around 10 miles away. Will this make a difference?
Thanks for the help, I'll get reading that lengthy trouble shooting guide!
08-10-2007 3:24 PM
08-10-2007 3:48 PM
Well, if you can give me the BT number I should try first (I'll get redirected all over the place) and I'll get my shouty voice ready!
08-10-2007 3:53 PM
Basically ADSL is distance sensitive. The further you are from the exchange, the weaker the signal quality, so if you had been connected to the exchange right next to you, your speeds would be far better than they currently are.
You could start with phoning BT on 150 as they installed your line, but we may need to go down the line of raising a fault with BT Wholesale and in all honesty, I don't fancy your chances, but I'll do my best!
08-10-2007 4:53 PM
I'll get onto them.
08-10-2007 11:20 PM
Also, another post mentions 'ghost packets', not sure if they mean anything but would like to know if its something that has been looked into.
Tom
08-10-2007 11:24 PM
I don't know how you mean ghost packets - is it some sort of term for cross talk? Can't say I've heard of that one before though.
08-10-2007 11:33 PM
As for the exchange, i'm guessing no one has heard of changing exchanges then?
08-10-2007 11:37 PM
3.28km away
Quote BT ADSL broadband availability
You are connected to the Wallingford telephone exchange.
ADSL is available in your area
Your exchange is also enabled for ADSL Max services
According to BT Wholesale, your line should be able to support a 2Mbps or greater ADSL connection.
Standard ADSL RAG results:
[BT ADSL Code: GEGEGEC] You can receive 2Mbps ADSL
[BT ADSL Code: GEGEGEC] You can receive 1Mbps ADSL
[BT ADSL Code: GEGEGEC] You can receive 512Kbps ADSL
[BT ADSL Code: GEGEGEC] You can receive 256Kbps ADSL
However, there is another service on your phone line (e.g. ADSL, LLU, DACS, etc) that would prevent you from ordering a new ADSL connection.
Your BT ADSL code is: GEGEGEC
[BT ADSL Code: GEGEGEC] = Green, obviously meaning Good to Go
09-10-2007 9:11 AM
That figure will be as the crow flies, rather than the actual distance of the cabling.
I have heard of cases where people have had their telephone line rerouted to a different exchange, but it is very rare and it would take quite a battle. Why BT Retail would have done that in the first place really does make very little sense.
09-10-2007 9:37 AM
09-10-2007 9:39 AM
I imagine potentially so, but I'm not sure if there are also distance limitations and obviously it would depend if cable were available in your area.
09-10-2007 9:43 AM
