More slowdown woes - help please!
- More slowdown woes - help please!
09-06-2011 9:18 PM
A week or so ago I had a problem with my download speed so ran a BT speedtest (below) and then raised a ticket. The result was the PN ran some diagnostics and identified a BT line problem. A BT engineer fixed the fault in a junction box at the end of my road this morning and speeds immediately returned to approx 8mb, which is what I normally experience and is shown as my estimated line speed.
Download speed - 1300 Kbps
Acceptable range of speeds is 4000-21000 Kbps.
DSL Connection Rate: 10422 Kbps (DOWN-STREAM), 443 Kbps (UP-STREAM)
IP Profile for your line is - 9194 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 22.78:22.45:54.8 (SBE:NBE:PBE)
I ran another speedtest tonight with the following results:
Download speed - 1524 Kbps
DSL Connection Rate: 18507 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 16328 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 25.45:25.79:48.78 (SBE:NBE:PBE)
The download speed has reduced to almost what it was before and I also notice that the DSL connection rate and IP profile have increased considerably. I can’t pretend to understand much about this but do these stats look correct? Is this still a BT problem – any help would be much appreciated
Message 1 of 7
(1,010 Views)
6 REPLIES 6
Re: More slowdown woes - help please!
09-06-2011 10:18 PM
What does this give for Current Line Speed https://portal.plus.net/my.html?action=data_transfer_speed
Message 2 of 7
(630 Views)
09-06-2011 10:22 PM
Estimated line speed 8mb - current line speed 2.5mb
Message 3 of 7
(630 Views)
09-06-2011 10:31 PM
That is the answer - I would phone Plusnet explaining that their copy of the IP profile needs fixing (that is what the "Current Line Speed" is supposed to match)
Message 4 of 7
(630 Views)
09-06-2011 10:32 PM
Thanks Jim - much appreciated
Message 5 of 7
(630 Views)
10-06-2011 11:34 AM
HI prodda,
I've changed the profile at our end to 17000 to allow for your profile of 16328. You should see the change shortly.
Jojo
Jojo
Message 6 of 7
(630 Views)
10-06-2011 11:49 AM
Thanks Jojo - it's 'flying' already
Cheers
Phil
Cheers
Phil
Message 7 of 7
(631 Views)
