More VPN issues
- More VPN issues
More VPN issues
09-04-2013 11:45 AM
Hi all,
MisterW managed to solve my VPN connection issues today which is great.
However now when I connect the connection works for about 10 mins then the internet and vpn both stop working and I have to close the VPN and open it up again. Could this be because both router and vpn start 192.168. Could this be causing a conflict maybe?
Any help appreciated as always
thanks
Matt
thanks
Matt
Message 1 of 3
(658 Views)
2 REPLIES 2
Re: More VPN issues
09-04-2013 11:58 AM
It depends on the next digit, if that's the same e.g both 192.168.1 then that WILL cause a problem. It usually causes the VPN to not work at all though...
Quote Could this be because both router and vpn start 192.168. Could this be causing a conflict maybe?
As a matter of interest, for future reference, which of the 2 commands here http://community.plus.net/forum/index.php/topic,113854.0.html solved the problem
Quote MisterW managed to solve my VPN connection issues today which is great.
Message 2 of 3
(376 Views)
Re: More VPN issues
09-04-2013 12:12 PM
Hi MisterW fyi the first command worked to set up the VPN
Message 3 of 3
(376 Views)
