More Line Droputs & Speed Issues
- More Line Droputs & Speed Issues
Re: More Line Droputs & Speed Issues
07-12-2009 5:13 PM
I have white with blue on terminal 2, white with green on terminal 3 and blue with white on terminal 5. I seem to have the opposite wires on 2 & 5 compared to what you posted earlier.
To answer your other questions: There is only 1 cable (round) from the main box to the extension box. When I remove the main box face plate, the extension is indeed dead. There is no sausage shaped capacitor in the extension box.
No recent decoration and no new electrical eqpt. As far as the neighbours - I don't know but I don't think so.
No flashing Xmas lights here but neighbours are starting to put theirs up inside & outside. However, my problem has been ongoing since late September and even my neighbours don't put their lights up that early. Also, no problem last Xmas.
The extension lead from the extension box to the router is flat. The lead is plugged into the extension box without a filter. The female end is plugged into the filter that is also connected to the router cable.
I do hope this can be solved simply as Jelv's and Jarvo's suggestions might as well be written in a foreign language for all the sense they made to me.
07-12-2009 5:43 PM
One thing you haven't tried yet is to use the extension socket upstairs without the telephone extension lead. If you could try that and post the router stats it might help clarify the best way forward (it might be as simple as buying a better extension lead).
07-12-2009 6:00 PM
My PC has no wireless capability so I can't follow Bob's suggestion either.
I am indebted to you all for all the time and effort you are putting in to assist such a techie buffoon.
07-12-2009 6:14 PM
If you could try in the upstairs telephone extension without the extra extension lead and post the stats we'll see where we go from there.
Have you only got a single PC (if that is the case it simplifies things considerably).
08-12-2009 10:34 AM
I'll try running from the extension box later today and will post stats.
08-12-2009 12:01 PM
Reason why long telephone extension cables can cause problems and ethernet don't: the telephone cables carry analogue signals and are susceptible to external noise, ethernet carries digital signals, is always made to a higher standard and includes error correction.
08-12-2009 5:20 PM
Uptime: 0 days, 0:02:22
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,240
Output Power (Up/Down) [dBm]: 11.5 / 18.5
Line Attenuation (Up/Down) [dB]: 27.0 / 49.0
SN Margin (Up/Down) [dB]: 20.0 / 15.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 10
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Good or bad?
Whilst I appreciate all the help so far, I would also like to improve my education so I would be really grateful if someone could give me a few pointers in what to look for in these stats and how to decide for myself how good or bad they are.
I have also experienced a couple of line drops today - both were under a minute and reconnected themselves ok.
To update on the noisy phone line, I think it may be the DECT phone as when I replace it with a normal corded analogue phone, there is no noise. I think that maybe my DECT has had its day!
So, back to the Bright Sparks for comment on the latest set of stats.
08-12-2009 5:56 PM
What happens is that the faster you sync, the lower the noise margin. The noise margin will vary depending upon the amount of other electrical background noise, if it drops to near zero you get a load of errors and the router/exchange will resync at a slower speed to give you a higher noise margin and thereby eliminate the errors. So that this doesn't keep happening BT set a target noise margin which is used when you router first syncs. This starts at 6, but if the noise margin keeps dropping to low they bump the target in 3db increments so that there is more room for the noise margin to drop before you start getting errors. You can tell what your target is by looking immediately after you have synced. Your target noise margin has been pushed up to it's maximum 15.
Can you keep things as they are tonight and do a reboot of the router tomorrow around midday so that we can get a comparison with the figures in the test socket at a similar time of day which you posted yesterday.
I'd also like to see what the figures look like when the DECT is unplugged.
*SN Margin = Signal to Noise Margin which is the difference between the level of the ADSL signal and the background noise
08-12-2009 6:10 PM
Just to clarify (I don't want to get it wrong :)) , I am currently connected to the extension socket upstairs (ie. without the extension lead). Do you want me to leave the setup as it is now and rebo0t the router from here tomorrow? If so, do you want me to unplug the DECT phone from the master socket before I do the reboot?
08-12-2009 7:41 PM
08-12-2009 9:07 PM
Thanks again.
09-12-2009 12:25 PM
Stats are:
Uptime: 0 days, 0:03:41
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,624
SN Margin (Up/Down) [dB]: 21.0 / 15.5
FEC Errors (Up/Down): 0 / 5
And with the DECT phone unplugged:
Uptime: 0 days, 0:06:47
FEC Errors (Up/Down): 0 / 14
Since connecting to the extension socket, my speed has increased quite noticeably. I ran a speed test last night and it came back at 1.6 Mb which is virtually back to what it used to be. IAs I've said previously, 'm not a technical genius but even I can conclude that this shows my extension cable is what is causing the problem. Would that be a correct conclusion?
So, based on earlier suggestions, I guess the way to go is to get hold of an extra long ethernet cable? If so, where might be a good place to go for one?
I await your comments with interest but if I am barking up the wrong tree completely, do try and let me down gently.
09-12-2009 12:32 PM
This can be more expensive as you ideally need a RJ45 crimping tool.
Failing that Cat 5 cables can be bought from the likes of Maplin if you have one local or a number of online retailers such as Ebuyer.
09-12-2009 12:38 PM
09-12-2009 1:00 PM
One last check on the DECT: while it is plugged in ring your home number and watch the noise margin, then use the phone and again watch the noise margin. If you don't see any change the DECT is in the clear.
