Monthly Broadband Usage
- Monthly Broadband Usage
05-08-2009 11:34 AM
Hi All,
Sorry im sure this isnt the correct fourm for the question but I couldnt see one for "account/billing"
I am currently a Pro member meaning I have a limit of 15gig per month, I normally wouldn't go above this but this month however I think I will, I have seen that in my account I can set a "Maximum Broadband Price" If say I put £25 in there which would give me 20gig but I only used say 18gig would I still get changed the full £25 or would it be closer to £23 ?
Thanks - Sorry again !
[Moderator's note by Dick (Strat) Moved from Broadband Speed to ensure appropriate exposure
Message 1 of 4
(742 Views)
3 REPLIES 3
Re: Not sure where to post this..
05-08-2009 11:53 AM
Firstly you need to consider the fact that extra usage is sold at £2 per 2GB - getting 20GB for £25 wouldn't be possible, it would be either 19GB for £24 or 21GB for £26.
That said, the maximum broadband price is a price ceiling, not an amount you will be charged each month. So if you were to set it to £26, Plusnet would charge you £20 per month plus any extra for additional usage, up to the maximum of £26.
Message 2 of 4
(345 Views)
05-08-2009 11:59 AM
Great - Thanks for the reply ill go change mine now ! 😃
Message 3 of 4
(345 Views)
05-08-2009 12:03 PM
@Oxigin
I have taken the liberty of changing the title of your thread to something more appropriate as others may find the thread useful.
Hope you understand
Kind regards
Dick (strat) Moderator
Hope you understand
Kind regards
Message 4 of 4
(345 Views)
