Modulation/Mode?
- Re: Modulation/Mode?
Modulation/Mode?
12-04-2008 7:18 PM
Where can I find the setting for Modulation/Mode on a Netgear DG834 v3?
Message 1 of 7
(1,914 Views)
6 REPLIES 6
12-04-2008 8:51 PM
Log into the router and go to ADSL settings. Drop down box against DSL mode.
Message 2 of 7
(594 Views)
12-04-2008 11:28 PM
Sorry, no win.
Message 3 of 7
(594 Views)
12-04-2008 11:40 PM
Looks like you need to upgrade your firmware!
You can get the latest firmware here.
You can find your firmware version on the router status page. The latest version is V4.01.37.
Message 4 of 7
(594 Views)
12-04-2008 11:54 PM
Is that ok for Vista64?
I was told dg834gv3_10Jan07_vista_3_3.zip was the one to use (10 Jan 07)
http://kbserver.netgear.com/kb_web_files/n101649.asp
ftp://downloads.netgear.com/files/dg834gv3_10Jan07_vista_3_3.zip
Message 5 of 7
(594 Views)
13-04-2008 10:01 AM
The firmware on the page I linked to will work fine with Vista. (The router that the screenshots were taken from is connected to two Vista machines and an Xp laptop.)
You'll also notice that bug fix no.7 on the page I linked to fixes an issue with previous "Vista compatible" firmware!
Message 6 of 7
(594 Views)
13-04-2008 10:17 AM
Thanks. How annoying is that? They give a specific Vista driver which is over a year old but the standard ones work too...
Message 7 of 7
(594 Views)
