Modifiying router local dns for server on lan
- Modifiying router local dns for server on lan
31-10-2014 1:44 PM
I'm trying to add the address of a local server to the dns server on the Technicolor TG582n so that when I type in www.exampledomainname.co.uk on my browser at home it will resolved to my local server. The webserver is accessible from the outside using the public ip address and serves up all of the expected media.
I've telnet'd into the router to see it there is any obvious command but haven't found anything.
Very grateful for any help - or even a link ... believe me, I've done lot's of searching so far!
Cheers
Re: Modifiying router local dns for server on lan
31-10-2014 1:46 PM
31-10-2014 1:51 PM
31-10-2014 1:53 PM
31-10-2014 2:04 PM
31-10-2014 2:06 PM
enter
menu
then navigate to
dns/server
then add the ip in there as a static ip
then exit the menu and enter
config saveall
to fix it over a reboot.
31-10-2014 2:09 PM
31-10-2014 2:16 PM
31-10-2014 2:19 PM
I don't have a TG router on line at the mo to give you the exact entries.
31-10-2014 2:26 PM
which gives:
Failed to add DNS host. [Name clash or invalid host name]
31-10-2014 2:38 PM
You want to add a redirect to the server then you would need to add something else like a CNAME which I don't think dnsmasq does.
With the basic setup you can add host names but not redirects.
So you could give it a name and then just enter the name into the browser
dns server host add name=web addr=192.168.1.10
then enter web in the browser and it should find the server.
Or change the default domain to example.com and make www the .10 address.
31-10-2014 2:53 PM
Looks like I'm going to have to set up my own dnsserver - never had to before. Tut tut Thompson, this is basic stuff.
Thanks for your input.
31-10-2014 8:35 PM
Quote from: buzzheavyyear OK. I've just tried adding a host: dns server host add name=example.com addr=192.168.1.10
IIRC dns hosts does not accept top level names. eg com, net, uk etc.
example.lan should work if that satisfies your needs.
02-11-2014 8:08 AM
02-11-2014 10:05 AM
