Modem WPS Light not lit
- Modem WPS Light not lit
16-03-2014 11:35 AM
Hi, I have a new modem from Plusnet, Technicolor TG582n. It was set up by Plusnet for my account and all I had to do was plug it in :). It's working fine. I have read the instructions, all the lights, dns, wireless, etc are lit green but the WPS light is not lit up at all. Is it supposed to be? Have I got security working?
Thanks.
If this is in the wrong place I will delete or move it, sorry.
Thanks.
Message 1 of 4
(7,096 Views)
3 REPLIES 3
Re: Modem WPS Light not lit
17-03-2014 12:52 AM
Fenster
From what i can remember WPS light on router only comes on if you press this to link up with other devices, as for security this should be set to WPA2-Personal this is the most secure setting.
Click on link below, fro understanding on what lights do on your router;
https://support.gradwell.com/entries/23135091-Understanding-the-lights-on-the-Technicolor-TG582n-bro...
Message 2 of 4
(4,578 Views)
17-03-2014 10:48 AM
Hi Fenster,
As long as you have a Green/ Amber light on the Wireless Light on your router, you are secure. The WPS light won't come on unless you physically press it to pair a device to it.
Message 3 of 4
(4,578 Views)
17-03-2014 1:26 PM
Thanks Markm9 and Chris. I will study the link, very useful. I have a Tablet and a smart phone which I have put the password into so they can now use the modem to connect to the internet. That is pairing? Anyway everything works, just wondered about the light.
Message 4 of 4
(4,578 Views)
