Modem Router advice
NatTheGooner
Modem Router advice
Hi
The Technicolor router supplied by Plusnet is fine at the wired stuff but the wireless is rubbish. (I know - you all said that it would be)
I get 74meg speed wired and about 12meg through wireless and I've tried all the channels and it is bad. Web pages seem to stick and hang.
So I'm after a decent all-in-one Modem Router for Plusnet Fibre.
I do a bit of gaming on the Wii U and I get an OPEN NAT OK with the Technicolor, I borrowed a Homehub 3 but could only get a MODERATE NAT so anything I bought would have to be a good all rounder.
thanks in advance.
NatTheGooner
Re: Modem Router advice
I've been looking, and I still can't find an all-in-one Modem/Router to work with Plusnet Fibre
Any ideas anyone?
Fixes: 16
Routers with integrated VDSL2 modems are not particularly common, but they are available e.g.:
BT HomeHub 5
Billion 8200N
DrayTek 2860n
Technicolor 589vn
I don't have any experience of any of those so can't recommend any of them.
itsme
Fixes: 21
There seems to be a lot of kit out there - see http://forum.kitz.co.uk/index.php?topic=9707.0
Also just do a Google search - the Frtiz!Box also comes to mind - expensive but respected.
Have you checked your wifi spectrum using the likes of inSIDDer?
NorthEasterner
I would suggest the hub 5.
I use it on my BT infinity service and I find it really fast.
No need for the openreach modem!
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Qdos
Whatever you do, remember to get something with IPv6 capacity because it'll be necessary sometime in the foreseeable future.
Unless you need simultaneous dual-band wifi I can thoroughly recommend both the Billion 7800 units, and the Draytek 2850/2860 series models.
NorthEasterner
hub 5 is compatible with IPv6
NatTheGooner
Thanks for the help everyone.
I think I'll try the Homehub 5
