Modem Replacement - New Plusnet Policy?
yfront
After the lightening storms over the weekend one of my referral's contacted me to say his broadband light on the modem was flashing. He'd already spoken to Plusnet and was told how to reset the router and then promised a call back that never materialized.
I took an old router over that synced OK proving his router faulty.
We then called Plusnet to request a replacement but was asked to pay £40 plus postage.
Up until now faulty modems have been replaced just for the cost of postage, did the Plusnet agent have this wrong or is this a change of policy?
All Star
Fixes: 6
Re: Modem Replacement - New Plusnet Policy?
I MAY be wrong here, but a 'faulty' router is one which has an internal fault, not one fried by matters beyond Plusnets control.
Fixes: 31
I don't think you're wrong at all @jab1, and makes perfect sense to me. But as your referral @yfront will need to buy a replacement, remember you don't have to buy from Plusnet, there are plenty others available for the same cost. Have a look on : http://kitz.co.uk if you need any recommendations.
All Star
Fixes: 6
Thanks @Mook - and agood point about alternatives.Thumbs Up
Gel
Seasoned Pro
Fixes: 12
Have seen Hub Ones on E Bay for 20 squids.
Your referral should invest in a surge arrestor socket/adaptor for that socket.
Fixes: 162
It would depend on the age of the device too and whether the customer was still in the minimum contract term.
 Chris Parr
 Plusnet Staff
yfront
Thanks for the response, would this mean he'd be eligible for a replacement within or outside of minimum contract?
On more than one occasion I've had referrals sent modems just to try, before Plusnet would progress a fault to Openreach so was under the impression that modem costs for Plusnet were minimal.
Been out to another referral this morning, filter and main socket blown apart by lightening and modem won't even light up, a really old one this time. I'll try again for this one.
I do try to look after your customers, my referrals, for you.
Fred
Fixes: 180
Potentially if the router was taken as part of the contract they're within the minimum term of.
If the account is out of the minimum term or the router was taken as part of a previous contract, I'm afraid it wouldn't be covered.
Having said this, if the account is no longer within the minimum term of a contract, they should also have the option to re-contract and take a new router for the P&P cost, as part of the new contract.
 Harry Beesley
