Moan
stathe
Moan
As well as my dismal speed the bt tester wont work and usenet groups are two days behind
stathe
Re: Moan
Configuration:
  Account: usenet.plus.net
  Server: usenet.plus.net
  Protocol: NNTP
  Port: 119
  Secure(SSL): 0
  Code: 800ccc0e                             Unable to connect to the server
Can anyone tell me how to check or cure this Thank You
James
Re: Moan
Have you recently changed your usage allowance from "fixed" to "PAYG"?
If so, that might explain things and a reboot should solve the problem.
stathe
Re: Moan
I wasnt  aware that I had , I just pay for the extra I use over my limit, I will Reboot  but fear it will be at a slower speed Thanks but I see my sessions always time out while posting .Why?
stathe
Re: Moan
Thanks ,the news has updated but I have reconnected at a much lower speed that is why I try not reboot too much ,but we have more than our share of bird strike power cuts Once again timed out while posting anyone know why?
