Missing broadband speed icon in connection settings
Hobbit
A bit odd but just noticed that the icon for letting you know your current speed which is normally in the connections setting folder is missing? Has this been moved?
It is normally got to by going into my account and then connection settings.
1 REPLY
Fixes: 101
Re: Missing broadband speed icon in connection settings
Topic locked as this has/is being discussed in detail here.
Customer and Forum Moderator.
