Mismatched profiles
- Re: Mismatched profiles
Mismatched profiles
04-05-2016 9:11 AM
Following a repair to a noisy telephone line I now have a much reduced broadband download speed of 30Mb/s when before the fault it had been a just under the maximum of 38Mb/s. The router was reporting a downstream noise margin of 12dB.
A BT engineer has come here again, reset the BT profile and said the line should be good for 44Mb/s. The router now reports a downstrean VDSL link rate of 40019kb/s with a noise margin of 6.2dB.
However the Plusnet profile is only 31.2Mb/s, with a download speed to match.
Can anyone help please.
Ticket #124085442 applies.
TIA.
04-05-2016 10:03 AM
Hi pittdj70,
OK so I have run some tests on your line and the connection is running fine and stable. I have also updated your speed profile on your account so all you need to do is reset your connection and you will receive the improved speeds.
04-05-2016 10:33 AM
Many thanks, downloads are now at a very respectable 37Mb/s.
04-05-2016 10:49 AM
Brilliant news. Well if you need any further assistance then just get in touch and we'll be more than happy to help.
