Mismatch
- Mismatch
Mismatch
20-03-2010 11:55 AM
Hi
After many months of fairly respectable times my speed has been brought down horrendously after a dodgy spell and doesn't seem to be creeping back up as expected
Furthermore there seems to be a mismatch between the BT Test who have me as 4500 down and Plusnet who have me as 3500 down
Anyone at Plusnet able to help me out on this ?
Thanks in anticipation !
Stephen
See attached screenshots for stats
Stephen
Message 1 of 5
(845 Views)
4 REPLIES 4
Re: Mismatch
23-03-2010 1:52 PM
Hi there hydester,
I've just looked at your account and ran a few checks for you. The 3500 profile has been set by BT and may have been caused by a low sync event, however tests show that this is not currently a problem. Our profile should rise to meet this after the connection has been up constantly for 72 hours so I would advise avoiding rebooting your router until that period of time has elapsed. Please flag this to our support team if you continue to have problems after 3 days
Message 2 of 5
(424 Views)
Re: Mismatch
23-03-2010 2:00 PM
Just to add to that, although the BT Speedtester is showing a 4500 profile, the reporting that we receive is showing 3500 hence our side having you set at 3500. I've upped this to 4500 just in case it's restricting you.
Message 3 of 5
(424 Views)
Re: Mismatch
23-03-2010 4:27 PM
Thank you both. Have just re-tested with BT & yes it is 3500
They really do punish you hard for an outage don't they ?!
Ridiculously so I reckon as my outage was not really bad
My uptime now reads as System Uptime: 268:54:39 so it should have updated by now !
Anyway thanks for your help & I will just be patient !
Steve
Steve
Message 4 of 5
(424 Views)
Re: Mismatch
30-03-2010 9:18 PM
Still seem stuck on 3500 IP despite being rock solid for days
Anything you can do about it at Plusnet ?
It seems pretty unfair & unnecessary
With thanks in anticipation
Stephen
Latest BT Speed Test attached
Stephen
Message 5 of 5
(424 Views)
