Miserable upload speed. Restricted by Plusnet?
minusnets
I have an extremely slow upload speed with Plusnet and I previsouly got double with Tiscali.
Are Plusnet capping my upload?
See results from BT - receiving 0.07mb out of a possible 0.45
Stats from router:
Please advise.
This is terrible...
Fixes: 62
Re: Miserable upload speed. Restricted by Plusnet?
it is capped at 445kbps and if uncapped would probably give a sync of 888kbps
But that doesn't explain the terrible speed test result - was that wired or wireless
minusnets
Quote from: Oldjim
Wired. It's been like this for months but I'm fed up with it now.
Fixes: 62
If you dial 17070 option 2 is the line quiet
Have you raised a fault at https://faults.plus.net
Are absolutely sure that you haven't got a peer to peer program running
minusnets
Quote from: Oldjim
I did this earlier using the master socket and it's quite as a mouse. I came here to vent as I discovered it when searching. I'll raise a fault on that site now. See if it gets anywhere. Thanks.
What router are you using ?
Looks like a draytek router interface.  I had issues appear suddenly with upload speeds that turned out that the QOS option had been enabled on the router, turning it off fixed the slow uploads.
minusnets
Quote from: Bud
Vigor Draytek 2710.
Router is on factory default settings apart from account information and as such QoS is not enabled.
Do you have a different router you could temporarily try ? If you try and rule out as much as possible it will make PN's fault finding a little easier when they pick this post up.
