Miserable upload speed. Restricted by Plusnet?
- Re: Miserable upload speed. Restricted by Plusnet?
14-02-2015 6:27 PM
I have an extremely slow upload speed with Plusnet and I previsouly got double with Tiscali.
Are Plusnet capping my upload?
See results from BT - receiving 0.07mb out of a possible 0.45
Stats from router:
Please advise.
This is terrible...
Stats from router:
Please advise.
This is terrible...
Message 1 of 9
(1,378 Views)
8 REPLIES 8
14-02-2015 6:31 PM
it is capped at 445kbps and if uncapped would probably give a sync of 888kbps
But that doesn't explain the terrible speed test result - was that wired or wireless
Message 2 of 9
(800 Views)
14-02-2015 6:33 PM
Quote from: Oldjim it is capped at 445kbps and if uncapped would probably give a sync of 888kbps
Wired. It's been like this for months but I'm fed up with it now.
Message 3 of 9
(800 Views)
14-02-2015 6:37 PM
If you dial 17070 option 2 is the line quiet
Have you raised a fault at https://faults.plus.net
Are absolutely sure that you haven't got a peer to peer program running
Message 4 of 9
(800 Views)
14-02-2015 6:39 PM
Quote from: Oldjim If you dial 17070 option 2 is the line quiet
I did this earlier using the master socket and it's quite as a mouse. I came here to vent as I discovered it when searching. I'll raise a fault on that site now. See if it gets anywhere. Thanks.
Message 5 of 9
(800 Views)
14-02-2015 6:40 PM
What router are you using ?
Message 6 of 9
(800 Views)
14-02-2015 6:40 PM
Looks like a draytek router interface. I had issues appear suddenly with upload speeds that turned out that the QOS option had been enabled on the router, turning it off fixed the slow uploads.
Message 7 of 9
(800 Views)
14-02-2015 8:45 PM
Quote from: Bud Looks like a draytek router interface. I had issues appear suddenly with upload speeds that turned out that the QOS option had been enabled on the router, turning it off fixed the slow uploads.
Vigor Draytek 2710.
Router is on factory default settings apart from account information and as such QoS is not enabled.
Message 8 of 9
(800 Views)
14-02-2015 8:54 PM
Do you have a different router you could temporarily try ? If you try and rule out as much as possible it will make PN's fault finding a little easier when they pick this post up.
Message 9 of 9
(800 Views)
