Miserable speed of 0.66mbps
m101dream
I have been left with unusable service since friday my internet speed has been capped at poor depressing 0.66mbps that's not acceptable. im really not happy with this unreliable service . i have attached few screenshots of my bthub-4 helpdesk, event log. test result and ADSL availability results hope this helps anyone.
thanks in advance
Fixes: 31
Re: Miserable speed of 0.66mbps
You should edit the first picture and removed your private credentials -  email/serial no,SSID.
Have you reported a fault? Is the line quiet? Have you followed any of the troubleshooting guides?
Fixes: 179
Your speeds have been banded because of the drops on your line.
I can see you've got a fault raised and our Faults team will get that picked up as soon as we can.
 Matthew Wheeler
m101dream
yeah matthew it has been banded but why? i have not seen such a slow incompetent customer service, i have called  the faults team once a day since friday midday and none has actually put a fault with your engineers. this has been done earlier this morning and thats unaccaptable to be told to wait for a call by friday 19th feb, that's  full seven day after the fault was raised. i have only been with plusnet for less then a month and already you've became a massively unreliable.
thanks for tip Mustrum Wink iv'e now edited the grab
